Question about Microsoft Office Home and Student 2007 Full Version OEM for PC
Problem Printing Excel file - Microsoft Office Home and Student 2007 Full Version OEM for PC
Posted by nanamalani on
Mynse Online
    New Friend:
  • 3 Answers
Steps to Fix Office Error Code 0-1005 (0):
A.Cleaning temp folder
  1. Press and hold the Windows key and the letter 'R' together.
  2. When the Run window pops, enter the command "temp", without quotes, and press Enter key.
  3. Now, you will have Explorer Window with the system junk files location open.
  4. Select any file or folder in the Window and then press and hold the 'CTRL' and alphabet 'A' at once.
  5. Now, right click the selected files.
  6. While holding down the 'Shift' key, select the option "Delete" from the pop up menu.
  7. If you are prompted to click on 'Yes' or 'Allow' or 'Continue', select the check box to the left bottom corner of the pop up window and then click on the visible button mentioned.
  8. Repeat the step 7. If the pop ups continue for more than a few times, select the option to the left bottom corner of the pop up window and click on 'Skip' and repeat the same.
  9. Once deleting is complete, you may close the Temp folder window and continue to next step.
B. Cleaning %temp% folder
The steps to clean the user related junk files is to follow the same steps above to delete the temp folder as above, where the command 'temp' is replaced with "%temp%", without quotes.
Content source:
Error Code 0 1005 for Microsoft Office Administrative Privileges required
Posted on Oct 23, 2018
Daniel Adjare Boateng
    Guru:
  • 195 Answers
You may find it easier to follow the steps if you print this article first. .... Step 4: Remove any remaining 2007 Microsoft Office installation files .... Microsoft Office Standard 2007; Microsoft Office Home and Student 2007; Microsoft Office Basic 2007; Microsoft Office Access 2007; Microsoft Office Excel 2007 ...
support.microsoft.com/kb/928218
Posted on Jul 20, 2010
Print excel files
why lbp2900 printer is not printing in excel file.pls help me
Jan 02, 2014 | Canon LASER SHOT LBP-2900 Printer
Canon pixma mp287
Are you sure the correct printer is selected in Excel? I would compare Excel print settings with Word settings, since Word is printing docs.
Dec 08, 2013 | Office Equipment & Supplies
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
Jul 18, 2011 | Office Equipment & Supplies
Problem printing Excel files with HP Deskjet 2640
لو سمحتم ارسلوا لي ملف تعريف الطابعة HP Deskjet 2640
Jan 05, 2010 | HP Deskjet 2460 InkJet Printer
Printing from MS Excel 2003 to MX860, ''print to file'' box pops up
Anybody find an answer to this problem? Windows 7 same problem Excel 2003??
Dec 07, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How to generate csv and data file
Archivos CSV son archivos de datos creados en Excel para campos variables que se pueden utilizar en cxwizard. Archivos JOB son archivos de texto que son utilizados para hacer una impresion automatica de etiquetas. CSV files are data files created in Excel for variable fields that can be used in cxwizard. JOB files are text files that are used to make an automatic printing of labels.
Dec 05, 2008 | SATO CX400 Thermal Label Printer
MY printer will not print Excel spreadsheets
I had this problem on my Vista pc but it was for all programs it would say its printing and nothing happened,what I did was leave the old one installed on the pc and created another and then deleted the old.But have you tried uninstalling excell and re-installing it to see if that changes anything, and when you reinstalled epson did you go to their site and download the updated firmware/software for the printer this could be another cause?!
Nov 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Printing excel attachments.
Try downloading the file and then print it
Jun 25, 2008 | HP LaserJet 2420 Printer
HP 1020 printing problems
It seems like the problem is not the printer, but your Excel file.
Jul 27, 2007 | HP LaserJet 1020 Printer
Microsoft Office Home and Student 2007 Full Version OEM for PC Logo
215 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
