Slider Lutron: Dual  Fan Control / Light Dimmer: 300w, Single Pole Logo
Posted on Jul 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find replacement knobs for the dual slider lutron fan light switches?
Anonymous
Level 2:
Novelist:
  • Expert 107 Answers
  • Posted on Nov 11, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
107
Questions
0
Helped
46348
Points
155
I don't think they're a standard off-the-shelf item. But I would call Lutron's tech support center at 1-800-523-9466 - they're available 24/7 and they'll probably just send you some.
1helpful
I NEED A PART. CAN YOU PLEASE GET ME IN TOUCH WITH A COMPANY THAT CAN SELL ME PARTS TO ONE OF YOUR PRODUCTS. I NEED A DUAL SLIDE DIMMER KNOB ONLY. I DO NEED THE WHOLE DIMMER COMPONENT. THANK YOU.....
Call Lutron's tech support center directly at 1-800-523-9466. They're available 24/7 andif you're just looking for a knob or part of the knob, they'll probably just send it to you.
1helpful
We have the slider lutron dual fan control/light dimmer single pole switch and need to install it to work with our fan/light combo which also operates with a remote. How do you install the combo switch? We...
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Gary
2answers
I AM REPLACING A LUTRON DIMMER SWITCH AND HAVE i THINK MADE ALL THE RIGHT CI=CONNECTIONS - COULD A FAULTY GROUNDING BE THE PROBLEM?
As a general rule, grounding will not affect operation of dimmer.
Type of dimmer, type of switch being replaced, type of load, and how you connect wires will affect dimmer.
Here is Lutron dimmer switch page
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
What is the load? Are you wiring dimmer to a ballast? Or fan? Or incandescent lights? Or florescent lights?
Are you replacing a 2-way or 3-way switch?
What color are your dimmer wires?
How many wires were connected to switch?
Can you re-install the switch, and know where each wire went?
Did you replace a light with a fan, and then want the dimmer to slow the fan? Not every dimmer will work with a fan, or florescent lights.
Dimmers cannot dim LED lights.
If I know what type switch you are replacing, and the type of load you want to control, and the specific dimmer you have, I can answer the question.
How to install
Lutron S2-LFSQ is made to control one ceiling paddle fan & 1 light. Switch will not work on florescent lights.
See manual
To use this product, your fan and light must already be controlled by 2 separate switches.
If you have just one switch that turns on the light & fan together, the S2-LFSQ will not work (without additional wiring).
Okay, you have two switches. One switch turns fan on-and-off. The other switch turns light on-and-off.
Here is wiring diagram from manual: See diagram larger
Here's how to wire:
-Before disconnecting wires from existing switches, mark each wire with tape and pen.
-There is one wire that feeds power to both switches > mark this the 'Hot wire' and it connects to Lutron black wire (if you are unsure about this wire, remove switches, separate wires, turn on power and test each wire to bare ground, tape tester leads to wood sticks so hands are away from power, Tester lights up on Hot wire)
-The switch that controls fan > mark this the 'Fan wire' and it will connect to Lutron Yellow wire
-the switch that controls light > mark this the 'light wire' and it will connect to Lutron Red wire
-Lutron Green wire or bare wire connects to bare ground wire.
LUTRON SINGLE POLE DIMMER WHEN YOU SLIDE TO THE BRIGHTEST LIGHT AFTER A 15 SECONDS IT DIMS ITSELF BACK TO HALF BRIGHT
Unfortunately, there really isn't a whole lot you can do here to fix it, any attempt you make to strengthen the grip on the slider may gum up something else in the process. Usually they test for this sort of thing before it leaves the factory so I'm actually quite surprised. The best suggestion I can offer is to call their technical support line (they're available 24/7) and they will probably replace the unit for you.
I need instructions on how to install a 3 way lutron dimmer switch to an exhaust fan motor that will be plugged into an electrical outlet
sorry i don't have what you need but i know that dimmers and fans never work well they always buzz from the lack of power you will actually burn out the brushes in the fan in a short time.
Do you have a fan / light switch that can dimm low
I have searched high and low for this. Can't find it. if you find one please let me know...
What I have done in th past is separate the fan and dimming with two devices and if you're in a multi gang box you can combine other switches into a combination unit, or add a side-car box onto the one you already have in the wall...
Top Slider Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Slider Electrical Supply Expert? Answer questions, earn points and help others
