Question about HP LaserJet 1160 Printer
I have HP LaserJet 1160 Printer, moreover it prints dim (light) print on paper. I replace its toner, yet it is printing dim printing..... can you give me reason, what is problem?
Posted by mahesholi25 on
Thomas Beitz
    New Friend:
  • 62 Answers
Hi, maybe the printer is in EconoMode. To disable EconoMode please open the printig preferences in Windows. On the Paper/Quality tab or the Finishing tab, deselect the EconoMode checkbox.
Posted on Jul 19, 2010
HP 1160 e cuts off side of page. How do I fix this?
Printing or paper?.. If printing check 1. check with another cartridge 2. check half test page(half test page while printing half page stop printer remove cartridge & paper see the image created on cartridge drum or not ,if not clean the Laser scanner assm, check on paper proper image or not if not clean the transfer roller.(looked like sponge roller located just under the cartridge location). beyond this trouble shoot, advised to send it to service center..
Sep 13, 2011 | HP LaserJet 1160 Printer
Hp laserjet 1160 printing is very dim what is problem.
Hi.do this pull-out toner cartridge then shake it and also cleaning using vacuum to get dust an dirt in censor mechanical area.test and print .if print dim again. need to change or refill that toner cartridge.
Jun 09, 2011 | HP Office Equipment & Supplies
My hp 1160 is very slow
First option : Try uninstall driver software then restart PC reinstall again. try to print.
Second option : Connect to other PC install software driver then try printing.
Third option : Try self test that printer maybe need change your toner or refilling.
May 28, 2011 | HP LaserJet 1160 Printer
Shadow prints in the left side of the paper
hello, if you already changed toner cartridge, and problem is still there, the fuser unit will need to be serviced or replaced.
Oct 11, 2010 | HP LaserJet 1160 Printer
Instructions for refill tonner
Changing the print cartridge
1. Open the print cartridge door, and remove the old print cartridge. See the recycling
information inside the print cartridge box.
CAUTION To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
2. Remove the new print cartridge from the packaging.
3. Bend the tab on the left side of the cartridge to break it loose.
4. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling.
5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the
cartridge.
6. Insert the print cartridge in the printer, making sure that the print cartridge is in position.
Close the print cartridge door.
CAUTION If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric.
Oct 31, 2009 | HP LaserJet 1160 Printer
Problem for HP LaserJet 1160 Printer Fatal error light pattern pls help with the hp laserjet 1160
Check if paper is in the printer because that may cause the print to show that light or maybe the hardware part are not properly fit to the printer
Oct 24, 2009 | HP LaserJet 1160 Printer
HP Laserjet 1160 and Vista
Download update from HP on Vista.
Jul 11, 2009 | HP LaserJet 1160 Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Sep 08, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 1160 Printer Logo
250 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
