Dacor ECD230 Epicure Stainless Steel Electric Double Oven Logo
Phil Macklin Posted on Jul 19, 2010
Our Dacor double oven gave us the U60 Cooling Fan error on the upper oven this evening. Where is the cooling fan, is it to be cleaned or replaced? Is there a place on the internet to download the service manual, so I can replace some of the easy errors> It there a web site that tells the complete list of errors on Dacor ovens? Thank You Phil Macklin
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on May 17, 2012
Anonymous
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1523
Points
THIS SOLUTION FOR THE U6O ERROR CODE ALSO WORKS FOR OTHER ERROR CODES. I USED IT FOR THE L60 ERROR AND IT WORKED LIKE A CHANP. THANKS
Stephanie
Level 1:
New Friend:
Welcome Back:
  • Posted on Jan 19, 2018
Stephanie
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1523
Points
Worked like a charm. I cleaned the fan and it and still didn’t work. Used the code and YES !! Thanks
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Nov 27, 2009
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Do i really need the cooling fan to work if i have bypassed the u60 code on Dacor oven
It obviously is requesting you to replace the fan and or the relay. If it comes with the oven it is definitely needed.. Bypassing anything could cause a fire and you would lose your home. I wouldn't bypass it. Please have it repaired correctly by an authorized repairman.
May 10, 2021 • Dacor Ovens
2answers
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
FixYourBoard.com will test and remanufacture the relay oven control board in this model. Each rebuild comes with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
2answers
Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
7helpful
3answers
Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
