When the ac acts up,test voltage at the ac clutch,if there is voltage(12 volts to 14)then the clutch is the problem,also,try and wiggle the low pressure switch ,to see if it tries to come back on,,,have some one put some ac gauges on the ac system and let the ac run,and watch to see if the low side falls down to 25 psi or lower,if it does,then the orifice tube is stopping up.If this was at all helpful,please rate,thank you.
There is the climate control CPU, the compressor, the compressor clutch, the freon level, the air flaps, and the evaporator orifice can be plugged.
