SOURCE: olympus camera FE-330 day month
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
SOURCE: Olympus e-500, when reviewing pictures
When in review mode if you press the INFO button it changes the information that is displayed on the screen of each image. You can keep pressing the INFO button and it will toggle through all of the various display information available.
SOURCE: Camera not properly reading memory card
The problem stems from deleting some of the images from the PC. You need to copy all the files onto the PC, and delete all of them from the card on the camera. Then reformat the card on the camera. Then take 1 picture on the camera.
After you have just 1 new photo on the card, try copying the older files back onto the card in the same directory as the 1 new photo. This may work.
If it doesn't work, the problem may be with missing hidden thumbnail files. In that case you may not be able to get the photos to display on the camera again.
SOURCE: My olympus e-500 will not display an image before
In order for your camera to display the scene on the screen before you take the picture (the way point-and-shoot cameras work) it would have to have a feature called "live view". Your camera, as far as I know, doesn't have it.
SOURCE: I can't connect my Olympus
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
