Ok so i bought a faceplate because i lost my other one and it says it works with this stereo but when i put on the faceplate it just opens but thats it.. It wont turn on so now i dont know wat to do return it? or can this be fix?
The new face plate needs to be coded to the deck. with the face on you need to press and hold presets #1 and #3 at the same time. keep on holding and press reset continue to hold #1 and #3 until the unit is in all lighting mode. press AM button one time. p-rom ok will display. press and hold #6 and reset at the same time. continue to hold until display comes on.
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
If you have lost the faceplate you need to order the original replacement from Pioneer (a second hand or one adapted from a different stereo will not sync with main unit). Here the US contact: Pioneer Electronics (USA) Inc. - Genuine Pioneer Parts.
Call your Pioneer local number and provide stereo part and model number to get the part.
Got to the following lik for your manual:
http://www.dualav.com/i/product/manual/xd7500.pdf
Refrence page 6 for instructions.
With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure.
Hope this Helps
L8R
