Question about Canon PowerShot SD1000 Digital Camera
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
Posted by hans1320 on
Anonymous
    New Friend:
Most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Posted on Jul 19, 2010
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
My camera will no longer show an image on the screen when i am trying to take a picture, and my pictures are coming out completely black. it is not the display button, what else can it be?
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A by flicking as described in the link with your fingertip.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
My canon powershot sd1000 camera is showing a black screen
Aug 27, 2010 | Canon PowerShot SD1000 Digital Camera
Blank screen when taking a picture
Yes it is. Press the DISP button on the back of your camera. This manually turns the screen on and off to save batteries.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
No image when taking a picture with Canon Powershot SD1000
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
408 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Paul Green
Are you a Canon Camera Expert? Answer questions, earn points and help others
