Searching for tv turns off but will turn right back?
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655) 2 possible reasons, either Lamp is gone or Ballast Supply got bad. Replace lamp first, in most cases it solved the problem. How old is this TV and did you replaced lamp recently? Thanks.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Hi.
Thats a nice tv you have there.
If your able to get free estimate from repair shop go for it.
It could only be dry joints but it could be loptx & other components which could be pricey.
