SkyScan 86709 Atomic Wall Clock Logo
Anonymous Posted on Jul 17, 2010
Time setting for skyscan model 88202cop , to set correct time in central zone
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1400
Points
You have to press the time zone button while holding down the small reset button with a pen, toothpick, etc.
Ned White
Level 3:
  • Master 2,100 Answers
  • Posted on Jul 18, 2010
Ned  White
Master
Level 3:
Answers
2100
Questions
0
Helped
811214
Points
6188
The clock sets itself, I have never touched mine, it just works, and unless you are sitting on a time zone, it should work. There is a set button in the back , I have never messed with it, It has an alarm on it too. Hope this helps.
Testimonial: "Great, simple instruction. Thanks..it works !!!!!"
1helpful
How do I change the time zone for model 31981B?
How To Set Your Time Zone
Time Zones around the world are identified by how many hours they are off-set from Greenwich Mean Time. US time zones are 5 to 9 hours behind Greenwich Mean Time and are identified as:
Eastern -5 Central -6 Mountain -7 Pacific -8 Alaska -9
Your SkyScan model 31981 is pre-set to Pacific Time. To set your clock to your time press and hold the mode button for 2 seconds. The off-set hours will appear and blink in the clock window. Press the up or down button to designate your time zone. Press the alarm button to exit time zone setting mode.
http://skyscanatomicclocks.com/manuals/31981.pdf
1helpful
2answers
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
6helpful
How to reset an atomic clock
Hello
Get into this site. You can select and see the user manual for your SkyScan atomeic clocks here. OK.
http://www.atomicclocksstore.com/manuals
16helpful
How to reset time zone for skyscan 86742?
Starting in time mode:
1. Press "MODE" (brings up alarm time) 2. Press "SET" (toggles between the four zones)
P - Pacific
M - Mountain
C - Central
E - Eastern
3. Once the desired time zone is set, press "MODE" to return to the clock.
2answers
How do you set time zone model 3229-1
Press the Mode button to display the alarm time then press the Adjust button till you get tot the corret time zone, press Mode again once have found the coreect timezone.
1helpful
How to set on central time zone.
Hello. The instructions to set these clocks are rather lengthy so here is the website. Find your model, or one like it and the directions are very straight forward. Regards, Joe
http://skyscan.info/content/manuals/25-model-86722.html
41helpful
3answers
How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
[email protected]
3helpful
Time not correct
press mode button once.
Then press set until the time zone is on the correct setting
then press mode again
Don't know how to reset
dear anneD.and guest.
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
ok.
Skyscan model 87800
and change your wished time zone (for help go through time zone codeing list) and select your zone then press set button to normal mode and adjust the current time.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
