Samsung SCX 4521F All-In-One Laser Printer Logo
Posted on Jul 17, 2010
I delete smart thru 4 by mistake and i want to reinstall again
Aftron AFLED4310 Smart tv
If your TV is still not working after disconnecting it from power and waiting a few hours, then it is likely that the files that were deleted were essential to the TV's operation. In this case, it is likely that you will need to have the TV serviced by a qualified technician.
How do i Reinstall my account on my samsung tab 10.5 after I accidently deleted it
You can't delete your account. You should be able to log in using the same credentials.
Deleted handset by mistake how do I re register it. your problem?
You can try removing the battery from the deleted phone. Then put the phone into the main charging unit, the one with the answering machine, for a little bit. Reinstall the battery and put in the main unit again. Let it charge a few hours and try it again. Hopefully it will renegotiate it's status and be recognized by the master again.
By mistake i deleted my pc's audio output device how can i solve this problem
Reinstall Its sound drives form motherboard CD or download driver form internet it will work again
Deleted smart card by mistake. want to get the pix back. Have a Olympus Camedia C-3000 Camera, 3.3 mega pixil. Is there a program to reinstate deleted pix?
Have you ever accidentally deleted pictures from your cameras memory card? Or pressed the Format button instead of delete button and wiped your card clean?
However, there are also a lot of good open source / freeware apps out there that can usually get the job done. And that’s where the nice people at CONVAR come in – offering a program called PC Inspector Smart Recovery , which can recover lost pictures for free. What’s even better is that it’s extremely easy to use and works well (based on my tests).
Please note that after you’ve lost the picture, DO NOT take any more pictures on the memory card, as writing new data to the card lowers your chances of recovering the picture. Also note, that recovering the picture is not 100% guaranteed, but there’s a good chance your picture will be recovered.
Step by step instruction, here it is: 1: Download PC INSPECTOR Smart Recovery.
2: Connect your memory card, either by a little memory card reader, or hook your camera up to the PC via the data cable.
3: Run PC INSPECTOR Smart Recovery.
4: Select the drive which is the memory card. It should be the one that has just connected.
5: Leave the format type as .JPG.
6: Choose a destination for the recovered files.
7: Press ‘Start’.
Hope helped with this. Good luck.
Smart Label Printer 430
Delete it from Control Panel, unplug the USB cable, then reinstall the softwre.
Motorola v635 mp3
You have to get it reinstalled again.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
