Yes your ok if they say the unit doesn't need to be changed in the incomimg power from 208 up to 230 volts or vice-versa,normally they classify motors as120/208/ 230 /460 volts, instead of 120/240/480 volts,but all line voltage varies in this voltage range between 230 to 255 volts a.c. with a +10/-10 percent tolerance either way,and as long as the instructions dont say anything about changing motor connections your good to go, just look on the motor body if possible and make sure theres no wiring diagrams to change voltage,but i would say no in a package A/C like that, and as far as the current goes your good with the 20 amp tandem pole breaker,let me know if i can further assist you. thanks
