Master
- Posted on Jul 17, 2010
Re: Color stopped rotating in Hayward pool light
How do I change the color options?
- Changing between the color shows is as simple as powering down the light (using a switch) and turning it back on within 10 seconds.
back to top
How many color choices do I have?
- Twelve (12) - There are five (5) static non-color changing options and seven (7) color changing shows. Each show is set and cannot be changed. The shows range from three colors, slowly fading from one to the next to a fast moving Mardi Gras show with over 1500 colors.
- Click here http://www.haywardnet.com/pdfs/UL_listings.pdf for a matrix of replacement lights. The new light fixture must mount in the existing niche. Once you’ve determined the niche installed, use the chart to see the replacement light that will fit.
NOTE: To help determine the niche installed, use the model of the light fixture removed. There are some characteristics of old niches and lights (i.e. location of securing screw, how the lens is secured, the label on the light, the size of the can etc.), which may aid in their identification.
