Question about Woods Freezers
Frost on wall - Woods Freezers
Anonymous
  • 360 Answers
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Posted on Jul 17, 2010
Testimonial: "thanks."
  • Anonymous Jul 17, 2010
    Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
    Take care
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Temperature Alarm
Can you look behind the food and shelves at the back wall near the bottom, if there is a frost build up on the back wall we have an issue with the defrost system, this would cause poor air flow and loss of cooling. I do not have your model number but I am assuming since it is a frost free unit it has an internal fan. If so is the fan running inside, can you feel air out the vent in the top? If not your fan motor may have gone out. The next thing to check is feel the side walls of the freezer, they should be warm. If they are not the compressor may not be running. Let me know the results of these questions and we can go from there.
May 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Brand new upright the back wall of freezer has a
i have filled polythene bags with paper scunched up inside.to fill any empy drawers this will stop all the cold air escaping and being replaced with warm damp air.....works for me.....
Feb 01, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frosts up at front then food starts to defrost
It would appear to me the system has a leak. Allow me to explain. When a fridge/freezer is "lo" on gas it causes the compressor to run far longer than usual. As a consiquence the motor overload shuts it down, potentially for a very long time, hence the contents thaw. The major clue to this a frost pattern on just one wall. Have a tech visit to confirm, but I suspect you'll be out of luck as far as a repair goes. Chest freezers are not easy to repair "lo side" leaks, which is likely what you have, because the evap. coils are in the walls. sorry, but I hope that helps in some manner. good luck
Sep 28, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Lost vacumn, door popped open alarm on
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Sep 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Freezers Logo
199 people viewed this question
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
