Question about Razor E100 Electric Scooter
Clicking noise only and scooter wont run
Put in new battery and charged it for 18 hours . Power light is on .When we turn the throttle for Scooter to take off and run , we getting a clicking noise only . Scooter does not move or take off just the clicking noise instead . Please help
Posted by isleseeya on
Camryn Bohl
    New Friend:
  • 3 Answers
First try and see if those battery were dead and try a different kind. If that doesn't work notify the person you bought it from or the store about it and ask for a trade in.
Posted on Jan 29, 2019
5 Related Answers
Anonymous
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
Anonymous
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
how did you fix the transistor? Can you send me the schematics. dgarbaty at hot mail dot com.
Posted on Apr 09, 2010
Anonymous
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
ROB
  • 858 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
Anonymous
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
No charge indication on throttle and motor doesn't work - New charged batteries.
Make certain the Batteries are IDENTICAL to the original. Any change of the Voltage, Current, or Amps will damage the motor or starter. Check all connections to see if they are properly set and Plus is to Plus and Minus to Minus. Check the Ground wires. Make certain all wires are insulated well, no cuts, peeling, cracks, or holes. Technically speaking, if you do not have test equipment like a VOM (Meter) you cannot check continuity (for shorts) and leaks.
If you are satisfied that we are tryting to help you, rate the person accordingly.
Apr 02, 2014 | Electric Currie EZIP 500 Scooter
I have a invacare agura mobility scooter with new batteries but the power lights fluctuate in use the lights go down fairly quick if i turn the scooter off for 2/3 seconds the lights go up for a short time
if it is not making a difference in speed sounds ok deep cycle batterys run at same amps until completely dead this is when they should be charged for 8 hours most chargers are auto shut off
Mar 18, 2013 | Invacare Health & Beauty
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
I have 18volts at the box that the battery leads go to and the consol leads go out of. the warning beeper goes off even when standing still and in neutral. i have tryed bridging the leads from battery to...
18 volts is not enough voltage to run this scooter. You have 2 batteries that should each read a max voltage of 13.5 volts each or 26 to 27 volts when fully charged and measured in series. 2 batteries that are 50% charged will read 24 volts. Your batteries are almost dead by this measuring method. Charge them up or replace them and your scooter should run. Hope this helps.
Feb 18, 2011 | Electric Mobility 4 Wheel Power Electric...
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
Scooter won't run
Hi, Well it sounds like you have a wire not connected or the Twist throttle part is bad. The best thing is to use Volt meter on each battery and make sure they are at 13 volts of more. If they are 11-12 volts the batteries are no good. When you turn the switch on does it make a Click sound? Take off your battery access panel it is where you put your feet. Your batteries have a red and black wire with a wiring harness attached to them. This is where you want to make sure they are plugged in. If they are Plugged in Your Scooter has to Have a Blown Fuse. Check these out and get back to me with what you find. Batteries last 1 year if you take good care of them.
May 09, 2009 | Toys
Schwinn S180 won't charge
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
Mar 19, 2008 | Transport Schwinn Rechargeable Portable ...
Razor E100 Electric Scooter Logo
3,294 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
