Samsung S860 Digital Camera Logo
Posted on Jul 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung S860 will no longer focus and will only take blurry photos. When you press the power button to off, when the lenses retracts, it beeps twice. Is this fixable?
Jonathan
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Jul 17, 2010
Jonathan
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
20446
Points
234
Yes, the problem of your camera still repairable and I hope only adjustment of focus or cleaning of gear inside of the lens.
If you can open your camera and try to adjust the focus gear or clean the gear inside of lens.kindly check alos if the cable is not broken and connected properly.
goodluck and thank you my friend
The camera turns on but it is all blurry. And when I turn it off it beeps twice and the lense won't go all the way in.
Sounds like your lens assembly is damaged, it isn't able to twist the lens appropriately in order to fully close it or to focus in on the images you want. You will more than likely need to have the camera serviced. In most cases if it isn't under its warranty it will be a repair ranging close to $100, which is typically the cost of a new camera. Check your date of purchase as camera's come with at least a 1 year manufacturer's warranty, and hopefully you can get set straight.
My camera lense popped half way in. and won't turn on
take out the lens unit disaassemble the lens replace the broken/deformed parts service it assemble fix it to get proper functionning.
What to do if my cameras taking blurry pictures? How to fix it?
Some thoughts...are you moving when you press the shutter button? Put your camera on a firm surface or a tripod and take a few shots....are they better? Do you press the shutter button half-way and allow the camera to lock in the focus before pressing the rest of the way?
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
3helpful
Samsung s860 camera lens will not close and is out of focus.
I hate to say it but your camera needs to be serviced. Might not be worth the repair. Try to take it to a local repair center that would offer you a free estimate....
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Shutter too slow and pics of people blurry. I have the camera on auto setting, push button half way down, focus, then all the way, take the pic. If the subject is moving AT ALL, the pic comes out blurry....
If your camera has a sport or action mode that would be your best option if your pics keep coming out blurry. These modes are made for action shots. Its worth a try!
Beeps when turning off and pics are blurry
try replacing the battery, cleaning the lens, or fixing the lens
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
