Tip & How-To about 1985 Chevrolet Chevy
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. 18436572 The firing order Small Block Chevy V8 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 35 ft-lbs. Cylinder Heads
Engine oil
(blind hole)Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs. Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs. Flex plate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Center bolt
(Harmonic Damper)
Engine Oil 60 ft-lbs. Bell housing
(Transmission to Block)
Engine Oil
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
65 ft-lbs.
Engine Oil
50 ft-lbs.
Oil Pump
Engine Oil
65 ft-lbs.
Oil Pan
Engine Oil
12 ft-lbs.
Thread Locker
20 ft-lbs.
Timing Cover
Engine Oil
6 ft-lbs.
Intake Manifold
(Cast Iron Heads)
30 ft-lbs.
Valve Cover
Engine Oil
3 ft-lbs.
Exhaust Manifold
25 ft-lbs.
Spark Plugs
No Lube or Sealer
20 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker
60 ft-lbs.
Thread Locker
35 ft-lbs.
Centerbolt
(Harmonic Damper)
Engine Oil
60 ft-lbs.
Bellhousing
Engine Oil
25 ft-lbs.
Fig.: Cylinder head bolt torque sequence-2.2L engine
Apply a coating of 1052080 or equivalent sealer to the cylinder
head bolt threads. Install the cylinder head bolts (within 15 minutes of
sealer application), then tighten them in the proper sequence first to a
torque of 46 ft. lbs. (63 Nm) for long bolts or to 43 ft. lbs. (58 Nm)
for short bolts and then tighten all bolts an additional 90 degree turn
using a torque angle meter.
Hope this helps (remember to rate this answer).
