Remove and inspect the drain pump. (access is from the bottom of the washer once you remove all screws holding the pump housing in the front)
If no debris found when removing pump or pump impeller is damaged - replace. PArt number 4681EA2001D.
If found debris when removing the pump - reassemble and check again.
Good luck.
