Question about Kenmore HE2 Plus Front Load Washer
My HE2 kenmore front load washer shows a code of F24....what does this mean please?
Posted by nevaklein on
Rick Ead
  • 1,998 Answers
Check the water tempreture sensor and connection to it
heres some info that should help ya
http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
my HE2 kenmore front load washer shows a code of - pdf.gif HE2 Error Codes.pdf
HE2 Error Codes.pdf
Posted on Jul 18, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Check the water temperature sensor on a kenmore he2 plus washer
I am having the same problem, one wire broke off from the plug. Can this plug be fixed or will I have to buy a new wire?
Oct 29, 2012 | Kenmore HE2 Plus Front Load Washer
Error code f24
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
Code F 24 what does it mean The washer dose not allow me to do anything when I push start. All the areas light up and flash with code F 24
The F24 error code indicates a problem with the water temperature sensor. code meanings should be under lower cover, remove panal.
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
Flashing F24
All Kenmore appliances are built by other manufacturers, therefore you will need to provide your complete model number in order for us to determine who made your washer. Once we determine this, we can diagnose your error codes for you.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will attempt to get your washer repaired for you.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 Plus codes F24. What does it mean and how do I fix it. It works on the Clean Washer cycle. It works on the Rinse/Drain & spin cycle if you shut off the 2nd rinse.
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor). A bad wiring connection or a failed control board could also cause this problem. If you have the technical ability to safely access internal washer components, you may be able to repair this problem yourself. Diagnostic steps would involve unplugging the washer and checking the wiring connections between the thermistor and the control board. A resistance check of the thermistor would be needed using a volt/ohm meter.
hope this helps....
Oct 27, 2009 | Kenmore HE2 Plus Front Load Washer
HE2-plus washer will not start. error, status light shows "F-24"
code F24
WATER TEMPERATURE SENSOR ERROR
sorry but the following information is for TECHNITION SERVICE(only)
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
"Was this helpful?"
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
2,469 people viewed this question
Michael Thomas
Michael Thomas
Lawrence Oravetz
Vernon Taylor
