Question about Dane-Elec DaneElec 2GB USB Drive Red Hard Drive
My DameElec 2GB is not working on my XP Computer
I am trying to copy some files to my DaneElec 2GB USB flash drive but my computer (Windows XP-SP3) is not recognized it. I have checked Flash Drive in two of my other computers (Windows Vista & WIn 7) and it works fine. Would you happen to have a driver or fix to get it to work in my Windows xp Computer? Just in case, I have checked the USB port on my XP computer using my HP Flash drive and the port works great.
Thanks,
Posted by dv8lifestyle on
Manikandan Raj
    Guru:
  • 825 Answers
Try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Posted on Jul 17, 2010
I just bought a Dane-Elec flash drive and only hours after removing it tried to use it once mpre. Now it is saying the flash drive needs to be formatted and when I try to format it, it says Windows cannot...
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Sep 01, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Hi experts, my computer indicates there's only 1,14 gb space left on my usb stick but really there's only 8 items on it that don't even add up to 1 gb all together. I want to put a movie on it, (there...
Most movies are about 4.5GB to 8GB, this is probably why your not able to put a movie on it. Secondly a lot of flash drives say its 4GB but really its 3.5-4GB. There must be something your overlooking as file size for ti to take up that much space. go to the properties of each file and look at the folder size, might find something you missed that's taking up more space.
May 03, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Hi, My 2gb red flash drive has all of my info on it, but it keeps malfunctioning---as in: the computer opens it, and then keeps opening it, until finally I get a message which says "Potable device...
Scan the device for Virus's first.
Secondly use CMD to copy off file(s): Make a folder on C: called USB. Then in command type: cd xcopy C:\USB /E /H /Y
Format the Device.
Dec 28, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
WONT BE RECOGNIZED BY MY COMPUTER SIEMENS FUJITSU (WINDOWS XP SP3)
Try the device in some other USB port on your computer.
Try the device in some other computer.
Mar 03, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
My 16g thumb drive won,t let me put a 12.5g blue ray movie on it
Normally when your computer is unable to copy a file
from a damaged disk it will abort and delete the portition of the file
it has copied.
Try
Unstoppable Copier
Jan 03, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Dell Resource CD - not working in Windows XP SP3 version
You are using the Dell Resource CD provided by the manufacturer. This CD may not work with new versions of Internet Explorer that come with SP3 installations (if you reinstalled from a Windows XP CD not provided by Dell or if you did the Microsoft SP3 update).
You're only solution would be to use your "Service Tag" number underneath, for laptops (or on the back/side for Desktops), of your computer and go to http://support.dell.com to download the drivers for your specific system. If this computer doesn't have the drivers for you to be able to go to the internet, use a second computer and go to the site. Then download the individual drivers listed (the latest dated drivers will work best).
Once you've downloaded mainly the Video, Network, Audio drivers, use a USB Flash drive (sometimes called USB Key, USB pen drive, USB drive, etc) and copy what's been downloaded onto it. Do not double click on the files while they're on the second computer.
Once on the machine with Windows XP SP3, double click on each downloaded file (1 at a time) and follow the on-screen insctructions to install the driver. You should be fine afterwards. :) Let us know how it goes, and rate us. :)
Jul 19, 2009 | Dell ResourceCD (2p730)
No instructions on how to put data on flashdrive.
JUST PUT IT IN PC/LAP TOP THEN FIND DOC OR DATA YOU WANT TO COPY ACROSS THEN RIGHT CLICK MOUSE ON THE FILE SENT SELECT SEND TO THEN THE FLASH DRIVE WILL SHOW THE CLICK ON IT , THEN THE FILE GETS COPIED ACROSS ITS EASY REALLY
Apr 07, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Feb 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Use of DaneElec 2GB USB
well..you will need more space than that...i recommend mozy dot com for this..
Oct 12, 2008 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Dane-Elec DaneElec 2GB USB Drive Red Hard Drive Logo
285 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
