Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
Chi Chu
  • Mitsubishi Master
  • 8,457 Answers
If u have a HD tv.U have the Dish Network HD box.U will able to get the HD progamming.Check all the programs u are watching is it in 1080i.HD all 1080i,if the programs play in full HD modes.
Posted on Jul 16, 2010
  • Mike.H-DISH_Network
    Mike.H-DISH_Network Dec 27, 2010
    Hi there this is Mike Houston of DISH Network customer service. I see you got good answers from SD Tech and Chu3505, and I want to add if you have the HD TV and DISH HD receiver you will get limited HD content such as your locals and premium movie channels and some PPV. If you have anymore questions please reply back to this.
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Is there a step by step process to connecting my panasonic plasma hd tv to my dishnetwork cablebox?
hi does your cable box have hdmi ports if so connect hdmi lead from cable box to to tv hdmi 1, if your tv doesn't have hdmi then connect scart lead from cable box to scart 1 on the tv hope it helps
regards
shaun
Jan 31, 2014 | Televison & Video
What are the connections to add a Home theater system to Dynex 26 in and Dish DVR network box
Hi my nameis Mike Houston of DISH Network and I see where you want to connect a HomeTheater system to the Dynex TV. Do to different systems are different and wedon't know the specific model of the Home Theater unit you are using the bestthing is to check your TV manual for best connections, if you have any questionsplease e-mail me at [email protected]
Jan 05, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Need remote code for dish network remote to control philips tv want dvr and tv to work off the dish remote
If you have not found the codes yet, follow the link below. The link will walk you through the steps to program the remote to the tv. They are simple steps.
Codes:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
If the codes do not work, try this link for a power scan, which will scan the tv for the correct code.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Aug 04, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I cannot get my hd box to overwride my analog tv
The hd box does not have hdmi over ride unlike the scart output. You havent said if this is hd ready tv if so most TVs will stay on the same av/hd input.
Sep 16, 2009 | Hitachi L32H01 32 in. HD-Ready LCD TV
Is this unit HD ready or do I need a box.
your tv is hd ready but you still need a HD box from your provider.
Aug 14, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Power off presents magic focus screen, tv must be unplugged.
you will have to determine if tv fault or cable fault, shut down cable box and unplug it`s power cable. Once all power is removed from cable co. equipment retry your tv controls, if tv turns on correctly problem with cable co, if not tv has corrupted data (try unplugging tv for 1 minute and then retry) ifstill bad tv has bad control board or logic problem, either one will require tv tech to fix, hope this helps, video-tek
Jun 01, 2009 | Hitachi 57F500 57" Rear Projection...
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
HL-R6167W tv reception problems
Are you using a Hd cable box/directv or dishnetwork box?Or you are using your coaxial cable straight into your TV coax input?
Solutiondoct
Aug 30, 2008 | Samsung HL-R6167W 61" HDTV
Remote code
Have you tried the website of DISHNETWORK.COM yet?
Jul 23, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
445 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
