Question about Lexmark E260dn Laser Printer
Have second hand lexmark e260dn and status light
I have been given a second hand lexmark e260dn (which looks brand new and driver CD has never been opened but have no manual). The status light is continously blinking. What does this mean?
  • 1 more comment
  • LXK Chris
    LXK Chris Jul 17, 2010
    The light indicates the printer is busy. Try to disconnect the printer from the network or computer. Are you able to print the menu settings? If it prints, then most probably it's a software issue.
  • Anonymous Jul 19, 2010
    I haven't connected the printer to anything yet as I wasn't sure if it was faulty.
  • Waston Ven
    Waston Ven Sep 12, 2018
    Lexmark Printer Customer Service Number is one of the best platforms which are available any kind of technical solution because sometimes the customer-facing some issue with Lexmark printer and they are don’t know how to solve that problem. We are providing support service for customer help by just dialing our toll-free number. We have very expert technicians who always ready for your help 24*7 hr.
    Lexmark printer has good features and gives better print quality.
    https://www.contactxpert.com/lexmark-pri...
LXK Chris
    Genius:
  • 1,087 Answers
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Posted on Jul 30, 2010
Testimonial: "Thanks for your help. It looks like this can't be repaired though so I'm getting a replacement."
Lights constantly flashing on Lexmark E260dn
http://support.lexmark.com/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=HO3026
That is a general printer error
Check for jams or blocks. you might have to delete the driver and clean the registry I use revo uninstall. then install the latest firmware
Sir Dana
Mar 23, 2017 | Lexmark E260dn Laser Printer
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
Dec 20, 2012 | Lexmark E260dn Laser Printer
How do i install my lexmark e260dn printer without the cd?
You can download the drivers online: http://bit.ly/OCGFMb. Just choose the Operating System of your computer.
Dec 13, 2012 | Lexmark E260dn Laser Printer
Como instalar driver para que ela imprime em postscript lexmark e260dn
Primero debes instalar el driver postcript para ese modelo, si no lo tienes descargalo en el siguiente link. Busca aqui el driver para tu sistema operativo.
http://support.lexmark.com/index?productCode=LEXMARK_E260&page=driversdownloads&linkSelected=node4^subnode3&locale=ES&userlocale=ES_MX
Aug 18, 2011 | Lexmark E260dn Laser Printer
Why my computer does not recognize lexmark E260dn printer?
The computer can not detect the printer for a number of reasons and this can be resolve by check the connection between the printer and computer. Please make sure you are using the recommended USB or Ethernet cable (network connected). Check the cable connections to the printer to make sure they are secure. For more information, see the setup documentation that came with the printer.
If connected to a network, make sure that the printer is connected to the network. Print a network setup page and check that the status shows Connected. If the status is Not Connected, check the network cables, and then try printing the network setup page again. Contact your system support person to make sure the network is functioning correctly.
For further assistance, please call Lexmark Technical Support.
Apr 13, 2011 | Lexmark E260dn Laser Printer
What does the second warning light on the lexmark printer e260dn mean? and how do you fix it?
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
Feb 23, 2011 | Lexmark E260dn Laser Printer
Just installed new printer Lexmark E260dn all lights flashing- printer does not print
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark E260dn Laser Printer
Lexmark E260dn Laser Printer Logo
1,489 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
