Question about Memorex MVD2022 DVD Player
Why does my dvd player have two pictures with PSCAN displayed across the screen?
    Genius:
  • Memorex Master
  • 1,550 Answers
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Posted on Jul 16, 2010
  • zieglerdonal Jun 08, 2011
    WITHOUT A MANUAL- WOULD NOT A SHORT LIST OF STEPS HERE TO DISABLE THE "P" SCAN BE HELPFUL???
  • G. Wilson Oct 14, 2012
    I don't have 'high definition TV'.. so I need to disable the function (split screen, PSCAN sign in middle)...but how do I disable the progressive scan?????????? There is No on/off switch on back, no drop down panel on front... there are only two inlets on back marked progressive scan... I am not plugged into them. Could anyone tell me what steps to take to shut off the progressive scan???? (I have Rogers box) G. Wilson
    New Friend:
Memorex dvd player doesn't play in color, plays color dvd in black and white. where is the color
Posted on Sep 03, 2010
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 563 Answers
SOURCE: memorex dvd player pscan split screen
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
Anonymous
on the back of the dvd there is a black interruptor, it should be set as PSCAN OFF. thats all folks
Posted on Jan 23, 2008
Anonymous
You cant improve on perfection !!!!! thanks Kitita .
Posted on May 18, 2008
Paul Hutchinson
  • 909 Answers
SOURCE: devide the tv screen in 2 and have PSCAN written
Pscan is progressive scan, go into the menu and turn PSCAN off
Posted on Mar 21, 2010
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
Thanks.
May 28, 2010 | Memorex MVD-2045 DVD Player
Devide the tv screen in 2 and have PSCAN written
Mar 21, 2010 | Televison & Video
PSCAN warning and screen is split in two
hotpoint first edition hvl211 has 3 flashing lights how do u stop this is there a reset you can do
Jan 05, 2010 | Acoustic Solutions Audio Players &...
The dvd player displays a big yellow box in the middle of the screen with PSCAN with an exclamation point above it. Also the screen is showing the right side with a wide split between them. This is the...
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Nov 03, 2009 | Memorex MVD2042 DVD Player
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
Wont play dvd's displays PAL
how to reset awa dvd player pscan, my player just wont do anything only displays pscan and it splits the screen
Jun 25, 2008 | JVC XV-S402 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
Pscan
i had the same problem. When i played a DVD on my Memorex player, a double screen displayed and a PSCAN message displayed in yellow. I simply toggled (switch) the PSCAN switch on the back of the DVD player. -Mike / Florida
Nov 21, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Memorex MVD2022 DVD Player Logo
862 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
