Whenever I change resolution to 1152x864, the monitor pops-up "Auto Processing" and suddenly moves the image "away" from the monitor so there are black stripes on the right and bottom of my screen. I can't change it back manually because the values don't allow me to move it enough to fix it completely.
SOURCE: Laptop shutdown when screen was move
I would suspect that you have an LCD cable problem. Either it has an intermittent open that is caused by the repetitive flexing of the cable by opening and closing the lid, or the connector on the end of the cable needs to be reseated.
Hope this helps.
Ron
SOURCE: external monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
SOURCE: The cursor jumps somewhere else on the screen as I
GO run type control then click mouse. there is four option button,pointer.pointeroption.hardwere, i think point optiom option may be change . reset it.
SOURCE: Inspiron 1750 Laptop Crashes Randomly When Moved
Please do a complete scan of the system. It might be affected with Trojan. Also, dont install the games in the OS drive.
Regards,
HP
The video cord from the screen to the motherboard plugin may be loose, check to make sure the cable plug is firmly plugged in, then remove and reseat back in place.
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
