Question about Yard Machines MTD Gold 20 HP Lawn Tractor 13AL795T004
I have a 20 hp MTD Yard Machine with a 46 inch deck. I was cutting some thick overgrown grass today and the belt started smoking. I immediately disengaged the PTO gave it a minute and tried to re-engage it. It immediately smoked again. I don't think the belt has ever been changed. Is the problem as simple as changing the belt or is there something bigger going on?
Posted by mikehaff on
Jim flowers
  • Yard Machines Master
  • 1,098 Answers
You should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Posted on Sep 20, 2017
5 Related Answers
Anonymous
  • 437 Answers
SOURCE: Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Posted on Oct 07, 2009
ee-nonsense
  • 29 Answers
SOURCE: I have a Murray 6.0 hp 20 inch push lawn mower. Ho...
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
Posted on Jun 04, 2010
Anonymous
SOURCE: my yard machine 14.5 hp briggs engine with 42
It’s a bad solenoid. Mine was located under the shifter plate?
Posted on Aug 08, 2010
mickey813
mickey813
  • 472 Answers
SOURCE: I have a yard machine 42 inch cutting deck 14.5
ck to see if the spring is broke it has one that pulls it back
Posted on Sep 08, 2010
Anonymous
  • 150 Answers
SOURCE: mtd ride on mower cutter blade belts smoke when
probably a bearing out on one of the pulleys. Disengage turn motor off try spinning each one by hand, you may be able to feel the bad one. You may see discoloration on bad one but probably not with deck on machine.
Posted on Sep 29, 2010
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
When replacing double stack drive/deck pulley,how do you keep it from scraping deck/20 hp,46 cut,02 model,yard machines??!
MTD part number 950-0960A This is a spacer that goes under the pulley stack. It should help to keep the pulley from rubbing on the deck. Hope this helps.
Apr 01, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a mtd yard man 22inch / mulcher . My question is how do I get the mower to start mulching ?
For mowers like yours, there are straight cut discharge blades (for bagging the grass) and there are more expensive upswept mulching blades. Any holes in the sides of the deck must be covered to mulch as the blade keeps the grass up in the air under the deck, repeatedly cutting it...over and over..till it falls on the ground.So use a solid deck with the upswept type blade.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Replace deck belt instructions.
A yard machine is made by mtd,if you have a computer you can do a google search on your yardmachine model to get diagram
May 04, 2009 | Garden
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Machines MTD Gold 20 HP Lawn Tractor  13AL795T004 Logo
3,694 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
john h
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
