Burners are dry, but electric starter won't stop clicking after the gas lights on all but one burner. Checked for dirt/grim, everything looks good on the starter and the burner components. Problem started a few months ago, came and went intermittently, not occurs constantly for three burners.
Hello, Jesse -
The information on this website may explain why the electric starter for your gas burners click:
https://1stsourceservall.wordpress.com/2015/08/07/why-does-my-stove-keep-clicking-troubleshooting-a-gas-stove-ignitor/
Best wishes.
SOURCE: Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
SOURCE: Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
SOURCE: clicking noise on burner
You'll need to replace the Spark module in the back of the stove. Remove the back panel, and there is a blue Spark module. You can find them on-line for about $65. There are only a few wires to un-plug, it only took me about 15 mintues to replace.
SOURCE: Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
SOURCE: Igniter continuously clicks
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
