You have to remove the steering wheel with a puller,and the lock plate ,with a lock plate remover tool,and the cancel for the turn signals,and then the turn signal switch,then you remove a screw on the right side about 2 o clock position,and the lock and key will slide out.
Yes and Care Must be taken when Doing so you Must Disconnect the Battery and Wait 30 Miniites before Doing ANY work Involving AIRBAG. The Steering wheel Removed Gives you access
WITH KEY
Remove or disconnect the following:
1)
Steering column is separated from steering gear and allowed to rotate.
2)
Centering spring is pushed down, letting hub rotate while coil (2) is removed from steering column. (If this occurs, refer to center coil).
CAUTION: Lock bolt assembly (11) is under slight spring tension from lock bolt spring (12). Hold lock bolt (11) in place while removing lock module assembly (15).
Obtain all remote transmitters for this vehicle.
1. Close all doors.
2. Insert key into the ignition cylinder but do not turn it.
3. Press and hold the Unlock button on door lock switch on drivers door.
Hold until instructed to release.
4. Remove key from ignition and then insert key into ignition without turning ignition cylinder and remove key.
5. Insert key in ignition a third time and leave key in ignition. Do Not turn ignition.
6. Release door lock switch on drivers door panel.
A Chime will sound 3 times indicating that you are in programming mode.
7. Press both the Lock and Unlock buttons on the remote up to 30 seconds.
A chime will sound 2 times if remote has programmed successful.
8. Repeat step 6 if you are programming additional remotes.
9. Remove key from ignition to exit programming mode.
NOTE: If you are having trouble getting this procedure to work, we have found that some vehicles need step 3 to be done before step 2
