I have a COMPAQ LCD color Monitor Agency Model Number: PE1231 Product Number: P9622A I plugged it into my desktop computer everything was operating fine. My computer recognised it has new hardware and asked to proceed with the installation, I then accidently pressed cancel. That's when the monitor wouldn't work. I have tried everything! The LED doesn't even light up. I have tried pluggin it into my laptop to use as an external screen(clone) which I had done prior to this but to no avail. PLEASE HELP!
Posted by NeedSpeed93 on
  • ddurgin Jan 06, 2009
    monitor was working, then went dead, suddenly, as previous person stated.
5 Related Answers
Printer Hater
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
myob247
Georgia B
  • 1342 Answers
SOURCE: New Acer Aspire SA90
Seems you are not alone.
Try these suggestions.
Posted on Apr 19, 2008
LaptopExpert
Garry Romaneo
  • 458 Answers
SOURCE: Laptop LCD won't display
Bad Video.... It is replaceable if you have dedicated Video,
Need to replace the motherboard if you have onboard (integrated)video..
Posted on Jun 08, 2008
Anonymous
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Posted on Sep 08, 2008
zam zam
  • 85 Answers
SOURCE: Sony Vaio Desktop Computer Hardware monitor found an error?
whts ur problem explain it
Posted on Jan 27, 2009
MY monitor compaq pe1231 . I CAN not load a display can you help me what is its problem
Im guessing you meant black screen totally never text there.
does the monitor work on other PC as it must?? simple no?
if yes, it is good and the unstated PC is bad.
if not, the monitor is bad, if this old monitor is very old
2 things fail.
1: CCFL lamps inside all died long ago. 2010 or older.
2: the screen saver inside IT is turned on, turn that off.
push the menu button on the LCD monitor.
then in the OSD turn off sleep TIMER clock..
lets say unstated PC is dead.
1: is the fans dead,? if desktop 2 fans must be good, spin and blow air and not be packed up in lint as most old PC are.
heard ,seen to turn, and felt to blow.(air flow must happen)
2: does the DVD tray eject.
May 01, 2018 | Compaq Computers & Internet
How to fix hp pe1245 17-lcd color monitor
i have a hp monitor hp pavillion f1703 where is the plug in on the monitor? can not find one. is it hidden or does it not need one?
Feb 23, 2012 | HP Computers & Internet
I turn on the monitor and Compaq 7020 comes on the screen in color for about 2 seconds then goes black. The computer is on and everything is plugged in correctly
use a flahlight see if you can see an image faintly in the screen, if so the backlight is failing. if not, check your VGA or DVI cable connection on both ends. sometimes there is more than one port on the back of the computer, try the other port if you have two of them,
Aug 27, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
LCD Monitor (Model Number M17FBA) Signal Out of Range
Hi
Start the computer in SAFE mode. F8 before Windows starts. Once in SAFE mode change the screen resolution to 600 X 480. Do this by right clicking anywhere on the desktop. Once done then reboot into normal mode.
Jun 03, 2010 | Scanport 17" LCD Monitor
I have lcd monitor benq 751which has inbuilt sound system, but after reinstallation of xp, the sound is not produced at all.
You need to go to the website for your computer, then click on Support. In Support type your computer name, Model Name, and Model Number.
(Example:
Lets say I have a Compaq Presario SR1110NX.
I would go to HP.com/Support.
Hp bought out Compaq.
I would type the computer name,
Compaq.
Model Name,
Presario.
Model Number,
SR1110NX
You will find this information on the back of a desktop computer, next to the Windows Product Key, holographic sticker.
OR,
it may be up on the side, {Top}, of the computer case)
When you get to the page, click on Software and Driver Downloads.
In Software and Driver Downloads, look for the Audio file. If there is more than one listed, click on the newest version. Look at the date.
There should be a small window that will pop-up, and you click on an empty circle to the left of -> Save. Then go below, and click on Save.
If you do not have your downloads set to go to your My Documents folder, (Start>My Documents), this audio download will go to your desktop screen. Close all windows, then Double-click on that file icon. Follow the instructions in the Installation Wizard.
Aug 02, 2009 | BenQ FP751 (White) 17" LCD Monitor
How to maximize color of monitor?
The monitor and laptop are not compatible or the cable is not properly connected.
Jun 12, 2008 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Power supply cord
Yes it is possible to get the product from HP(as now compaq is owned by HP). The part number of the product is 259055-001. You can ask for this product from HP by calling them at 1-800-227-8164. They may also give you a better alternative part number for the power cord. But according to me this particular part would be best for you monitor(259055-001). You can also buy this product online from hp.com. Yes in fact you can use sony pc tower to display on this monitor.
Aug 13, 2007 | Compaq FP 7020 17" Flat Panel LCD Monitor
LCD Monitor should display 1280 by 1024, but only 640 by 480 and 16 colors avlbl. in control panel/display/settings. i've tried everything imaginable-virus removal,reinstalling drivers, (there is no...
You should try to update the driver for the display adapter, not the monitor. right click my computer>hardware tab>device manager if anything, that should be it. You like staying with win 98?
Jun 09, 2006 | Sony SDM-HS75/B 17" LCD Monitor
Computers & Internet Logo
69 people viewed this question
Ekse
Marvin
Marvin
