I'm recording my sound in an ambient noise free room and the sound levels on the display look fine. However, when I listen through the headphones or play it back in adobe, there's a high amount of static noise. No matter what I try it just won't go away or even lessen. Anyone know how to fix this? It's ruining the sound on anything I record.
95% of the time, it's a poor ground connection. Some of the time though it can be caused by a defective op amp on the audio board. Last thing that I can think of is the version of the adobe and the other audio programs, if they are not the pro/ paid versions, they sometimes introduce all sorts of noise. If the noise sounds like an old dial up modem, this might be the problem.
SOURCE: Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
SOURCE: external stereo mic into camcorder not recording audio
You cannot simply attach a mike with a 3.5mm jackplug by using an XLR adaptor, the connections are all wrong. The only way to connect an XLR mike to the XM2 is by using an adaptor like the Beachtek XLR adaptor which is a superb bit of kit. I can't be certain of your problem but may I suggest possibilities? I wonder if the adaptor you bought was a stereo adaptor. If it looks like a larger version of the original plug then fine, if it has only the one long metal contact along the pin and then the tip separately, it is a mono adaptor. Using this on a stereo mike would work but it would be combining both channels into one which would degrade the sound and could give rise to your noise issues. If you have got an adaptor that is stereo, is it just the push in type? You can get adaptors that have a threaded barrel to screw the adaptor to the normal plug to lock them together tightly. If it hasn't got that, I would try putting the adaptor on the mike's 3.5mm plug and then taping it together to hold them very tightly together. This will stop minute movements between the two causing buzzing and other noises. I hope you find that of some help, my apologies if not. Rob
SOURCE: Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
SOURCE: canon ZR65 camcorder issues
The CCD is not involved with playback, only the read heads. Your CCD could indeed be faulty. If the audio failed, it likely has circuit board issues which may affect the CCD even though it is working.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=227&modelid=8620
This page details FAQ's, and authorized service centers where you can get it repaired.
SOURCE: Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
