Tip & How-To about Computers & Internet
How to watch uk TV Online FREE!!
  • Most U.K channels also provide an on-line streaming service to allow users from within the U.K to watch programmes after they have aired on the channel on digital t.v.
  • All websites are free and require no logins or registrations just select what you want to watch and click play..
Computers & Internet Logo
how do I get it to work?
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into ...Roku Search makes it easy to find what's on, where you can watch it for free, ... At a wifi-enabled hotel or dorm room, just use your connected device to sign in ...
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...
Roku Streaming Stick Review & Demo - YouTube
? 5:03
https://www.youtube.com/watch?v=mSqMMJSPkBU
Oct 29, 2012 - Uploaded by totalhtpc
Many described the Roku Streaming Stick as one of the most promising ... My Tv does not have MHL port how to use thisRoku stick? thank you.
Problems streaming Netflix movies Continuously
There are a few things you can check. Mostly it is about how much demand you are using versus the service, and hardware you use, to provide it within your home.
The service level (bandwidth) is what you have purchased. This is a maximum and can go down considerably depending on time of day and who your provider is.
Do you have other users putting demand on your internet service - this may include neighbours who could be using your wireless internet if you do not have security turned on (ie password protected). Also if you have a lot of users, your wireless router may need to be upgraded to cope with the demand properly.
Is your tv wireless? This requires a good signal - if your router is far away within the house or buried behind heavy materials it may not be able to provide a 'fast enough' connection to your tv to stream your videos.
Netflix has 3 quality settings you can choose - if you have a lower internet service, the highest quality MAY be too much, especially if there are other users at the same time. Usually a 5 or 6 meg service can be at threshold for the highest quality setting depending on the 'actual' speed of your service at a given time.
To keep yourself happy while you resolve this, choose a lower quality setting on netflix - this should allow you to watch without it buffering all the time.
So what has changed since you got your tv? If the setup is all the same, then maybe you have more users. Check your security on your router. Has anything been moved? If so there is opportunity for cables to have been damages (or bad connectors) and also signal loss.
If you have a slower service, perhaps demand in your area at certain times is lowering your service enough to caused buffering issues.
3answers
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the case....squares and dropped signal. What more expensive equipment do I now need in order to pick up the old free local network channels? DISH? Direct TV? There must be a way to access these local channels without subscription to satellite companies, as these free local channels were available before the change over. Or, perhaps not.......
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
