The printer head for my kodak 5500 keeps saying "printer head missing, not installed correctly or has come loose. Install printhead and ink cartridges , if already installed, remove ink cartridges and printhead, then reinstall." ive already done what it has all said several times and ts still poping up. what do i do?
SOURCE: Kodak printer 5500 will not print in black
Go to www.kodak.com/go/printheadsupport to get instructions how to remove the old printhead and on how to install the new one.
SOURCE: change printhead in 5500
To change the printer head on the Kodak 5500 AIO printer, you will need to do the following:
To remove the old printer head,
To install the new head,
I had the same problem and wasted money on 2 new cartridges before finding the answer on several blogs. Call Kodak Tech Support. In this case they are very good. Tell them the problem, they walk you through some steps and then give up. They will then send you out a new print head (a cheap and disposable device). I thought about buying another one for the next time things go bad but I can't find a source. They send it in 3-5 days, free. I think Kodak is embarrassed about their bad system (printheads should not go bad so fast!)
SOURCE: REMOVING OLD AND PUTTING IN A NEW PRINTHEAD FOR KODAK 5500
Remove both cartriges and on the top left there will be a button. Push and remove the printhead. Net, take the new one and insert it, pushing on the thumb picture. Reinsert cartriges and align.
SOURCE: My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
