Question about Ricoh IS 330DC Flatbed Scanner
Installation of IS330DC on Vista 64
Good day all,
Pls I need help.
I have successfully installed the IS330DC (Network scanner) driver on the Vista 64 machine but when I click on scan, it comes up with an error ''36851: No response from the scanner''.
I am able to ping the scanner IP address from my machine.
The scanner has been tested to work well on Vista 32 machines.
What else can I do?
Posted by wilfredabolo on
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Posted on Oct 23, 2007
Anonymous
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
Anonymous
  • 159 Answers
SOURCE: I can not use the
Visit the Ricoh download site and download the latest driver. This will ask you if you wish to overwrite, say yes. Hopefully this will replace the corrupt file.
Posted on Aug 02, 2008
Anonymous
SOURCE: network printer installation problem
Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
Posted on Feb 14, 2009
Anonymous
SOURCE: Scan to email gives server response error.
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Posted on Mar 23, 2010
HAVE ACCIDENTALLY DISINSTALLED PRINTER X 3550
It is my pleasure to guide you.
Click this link http://www.siliconguide.com/drivers/device/188/
This site is "Free download and instructions for installing the Lexmark X3550 All-in-One Printer Driver for Windows 2000, Windows XP, Windows Vista, Windows XP 64-bit, Windows Vista 64-bit, Windows 7, Windows 7 64-bit. For those who have lost the installation CD."
Look through the OS listing and then click the Download Link at the right.
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 12, 2011 | Computers & Internet
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Where do I get a Windows 7 driver for the Iriscan Express 2?
The IrisScan will work with Win7 32-bit. This from both the Microsoft Compatibility Center and the manufacturer's web site. In that case, just plug in your scanner and the correct driver should load (go to Windows Update on your computer to finish the installation, if needed). However, if you need a 64-bit driver, you are currently out of luck. They only have a 64-bit XP driver (no support for Vista or Win7 in the 64-bit version.)
I hope this helps.
Dec 20, 2009 | Iriscan Express 2 Flatbed Scanner
I am trying to install canoscan fb630u scanner with vista 64 bit. the scanner does not support vista
Try Vuescan from Hamrick. I have used it to successfully scan from FB636U on a XP 64 installation and Vista with no drivers needed. A free trial is available. www.hamrick.com/
Aug 14, 2009 | Canon CanoScan FB630U Flatbed Scanner
Installation of e-studio 350
U need to confirm the driver support Vista 64bit.
U can obtain the driver at:
http://www.copiers.toshiba.com/support/controllers/ebridge350-450.shtml
Jan 19, 2009 | Toshiba e-Studio 350 Copier
Incompatible with Vista 64-bit
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Aug 26, 2008 | Canon DR 2080C Path-Through Scanner
Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your printer...you'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Jan 18, 2008 | HP Pavilion Media Center a1330n - AMD...
Ricoh IS 330DC Flatbed Scanner Logo
94 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
