Question about Briggs & Stratton Garden
I have a toro z380 zero turn. when you start it it will run fine for a minute then bog down real bad and blow out smoke really bad then it will run fine for a few seconds and do it again. it appears to be a white smoke. any help would be greatly appreciated. im pretty mechanically inclined as i work on small engines alot. i thought id seek some help on this one
Posted by larrymayes07 on
Kevin Hughes
    New Friend:
    Problem Solver:
  • 9 Answers
You may need to look at your rings as the oil ring on the piston may need replace your rings could be done how old is the engine if you ring me on 07849461942
Posted on Sep 23, 2017
5 Related Answers
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
Anonymous
  • 5 Answers
SOURCE: Craftsman riding mower starts, then runs for 30
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Posted on Mar 22, 2009
wadembly
Wade Mobley
  • 513 Answers
SOURCE: engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Posted on Jun 08, 2009
Anonymous
  • 32 Answers
SOURCE: lawnmower is spewing white smoke
your Tractor is probably burning oil bad. check the oil, there could be too much oil or too little.
Posted on Jun 12, 2009
Anonymous
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
Honda gx620 on golf cart occasionally bogs down & blows enormous cloud of white smoke from exhaust.gas getting in oil also.runs great until this happens
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
Feb 26, 2014 | V-Twin Horizontal OHV Engine with Electric...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
I have a 1986 GMC P/U Truck with a 305ci. It has a quadrajet Carb that has been rebuilt. The problem I have is that it wants to "Bog" while going down the road like the A/C came on or like you...
You may have a leak vacuum or part. Check hoses and then fittings. A switch is changing or temp sensor maybe be an issue also. Check engine codes also
Dec 29, 2017 | 1986 GMC C1500
Trouble starting and a lot of black smoke at startup
Could be. Black smoke means too muck fuel or not burning properly. Also make sure your oil is not over full.
Apr 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
New Poulan gas mower blowing white smoke
if its new carry itback theres a number of things it could be but it sounds like the crankcase is full of gas check the oil and see if theres gas in it.
Oct 25, 2009 | Toro Lawn Mower With Toro Power Tools
My truck runs fine at times but then it will bog
Hello there:
the way you are describing it it is sounding like the fuel filter is started to clog and might need to be replaced.
you may also want to look into a tune up i.e spark plugs and wires and rotor cap and air filter ect ect ok?
best regards michael
Sep 10, 2009 | 1992 GMC Sierra
Mower starts then it smokes
If you spilled any oil on the engine, it will smoke for a few good minutes until it burns off.
Or, you may want to check the air breather. It may be dirty.
Jim
Jun 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
131 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
JOHN LAPIER
dannydoesita
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
