Question about Sony Cameras
SOURCE: format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
Posted on May 31, 2008
SOURCE: sony memory stick pro duo format error
when i turn my camra on its does nothing it has a black screen and it don't turn off then when i take the memory stick out it works and turns off with no problem
Posted on Sep 21, 2008
SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Posted on Nov 14, 2008
SOURCE: Memory Card Problems
Formart the card, either from the camera, "if it offers the option, most do" or if you have a memory card reader in a desktop or laptop, that is what it sounds like to m, best of luck Gym
Posted on Dec 22, 2008
SOURCE: How can i fix my memory stick pro duo if the computer does not detect it?
Hi Guy's!
Don't brick/bin it It is probably fine Your P.c. can possibly only read a Max of 2Gb so buy yourselves an external card reader that can read up to 8Gb or more and your back on the case.
There you Go FixYa'd
Paul 'W'
Onyer~EDson(:0)~[>< U.K.
Posted on Jan 09, 2009
