Question about Refrigerators
Refrigerator rubber door handle
I have a ten yr. old GE Refrig. that the rubber door handle is turning brown from use, it looks ugly and I don't want to replace it. Any suggestions on how to paint the rubber. Also the chrome around the handle is wearing off and turning black, any solutions for that. The Refrig is in great condition except for that...thanks, Sherry
Posted by SHERRY 64 on
  • thisisacrock Nov 01, 2008
    We are planning to put our house on the market. All the appliances are great except the rubber door handle on frig. I tried every product I can think of even straight bleach with no luck. Could I paint it???? Please help - we want to sell this house sooon
Chris Huff
    Top Expert:
  • Refrigerators Master
  • 6,289 Answers
Go to searspartsdirect.com with your model #. Find part # in parts list for handle. Then go to eBay, Amazon, etc and do search for part #.
Posted on Nov 03, 2017
Bill Boyd
    Top Expert:
  • 53,812 Answers
No fix
any paint you use will wear off and any chrome paint you use will wear off also
GE spares may still have the items as spare parts so call them
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: doors staying closed on refrigerator
It happens from not being cleaned and the gasket sticking when u open the doors
Depending on how bad the rips are... you will need to replace if too bad.. i have used silicone in a caulking tube .. to repair them.. use vasoline after to keep from sticking to the door on fram or door and on gasket
Posted on Nov 05, 2007
MARLON KELLER
  • 111 Answers
SOURCE: GE Model # GSS201EPJWW
bad main processing board
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 13, 2008
Anonymous
SOURCE: Sub-zero Refrigerator Door
We have the same problem and were told to apply vaseline to the rubber edges of the door; this did help.
Posted on Sep 27, 2008
Anonymous
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
Techsim
James
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
I have a 10 year old GE Monogram refrig. We noticed a small puddle of oily liquid on floor beneath freezer door. It is accumulating about 1 tsp/day.
certain amount of oil is in the compressor motor casing to stop it burning out
it is under the same pressure as the refrigerant
I would say the oil comes from that casing
you could turn the fridge off at the wall
bring the fridge out to get behind it
and degrease the area to see if the leak is severe
if it is..... needs a fridge technician
not sure
check if cost of replacing the motor compressor unit
on a ten year old ge
might be more that fridge is worth
Nov 10, 2016 | GE Refrigerators
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE side by side- water and ice dispenser are not working. 5 yr old refrig/freezer.
This would be your inlet valve located behind the rear access panel. Rate me if I am correct, thanks!
Aug 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
R door- GE 21.6 is slipped down. Gasket cant seal, part needed?
the parts detective dot com has all sorts of repair parts. You'll need the model and possible the serial number.
Aug 11, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Oct 24, 2007 | GE GSS25JEMWW Side by Side
GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date.  Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you.  Call 1-800-905-9505 for service.  They are nationwide (US).  If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker.  Unfortunately these come as a whole unit and can't replace parts.  Once you have the correct part # I bet will find a good price on ebay for a new ice maker.  If you need help finding the part # or any other questions let me know.  If you feel I didn't help solve your problem please let me know before you rate this solution.
Oct 12, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
714 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
