Question about Ovens
I own a secondhand "leisure zenith 50 electric oven" i need a users guid or something so i can learn how to set the timer.is there one i can down load?ive been searching the web with no help.is there a web site that ask's you your make and model oven or applience then displays an ansew for me? hope you can help
JonSnell Electronic
    Top Expert:
  • Ovens Master
  • 31,814 Answers
Have a look here;
Manuals Leisure
Posted on Dec 21, 2017
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
Posted on Sep 19, 2006
Anonymous
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
Anonymous
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
phreich
  • 5 Answers
SOURCE: Finding parts for La Germania- Explorer Oven
The distributor for LaGermania in North America has gone out of business. However, parts can be ordered directly from the manufacturer in Italy. A contact that worked is: Daniel Pedrazzini
Customer Support
BERTAZZONI S.P.A.
phone +39 0522 226415
fax +39 0522 226440
e-mail: [email protected] that shipping will be expensive, but it is still much less than buying a new stove.Also, I have found a model sold in Australia that is very similar in features to the models that were sold here, with the exception that they don't have a separate burner lighting button. Here's a link:http://sampfordixl.com.au/lagermania/upload/LUEP01-90-S._W1883_%28A.pdf
UPDATE: (January 5th, 2018)
Unfortunately, the Australian distributor no longer carries the La Germania line, and has removed all La Germania related information from their website. I uploaded the manual I had gotten from the above dead link and also the parts breakdown drawings and parts list that were sent to me from the parent company in Italy, Bertazzoni. This parts list can be used to order parts from Reliable Parts, which is a U.S. distributor of Bertazzoni parts, and they can order the La Germania parts using the parts numbers from this list by contacting their Bertazzoni reps and getting the Bertazzoni part numbers where they differ.
Here's a link to the directory that contains this information on a Google Drive. Using this link you should be able to browse, view and download the documents:
https://drive.google.com/drive/folders/1dYHsPsU-_WZ71kR4nLobiv7thY-lJV2t?usp=sharing
A few notes that may help people when repairing these 1990's La Germania branded stoves:
1. These La Germania branded stoves are well built and worth repairing. They are the same quality and similar build as the stoves currently being sold in the U.S. under the parent company's name, Bertazzoni. After replacing two burned out oven heating elements (see below) in mine in 2008, it has been operating flawlessly for over 10 years -- pretty good for a 1990's dual-fuel stove.
2. Some of the electrical elements can be replaced with domestic parts. For example, I took the burned out circular convection oven element to a local used appliance store (used appliance stores often have appliance repair departments) and was able to match it up exactly to a used convection element they salvaged from a domestic stove. Unfortunately, because this was a salvaged part, I was not able to determine the make and model of the "donor" domestic appliance, otherwise I would have posted it here. However, their technician assured me that it was a commonly available part. You just need to match up the dimension of the round element (both diameter, and depth) and make sure the wattage rating is about the same -- in my case the one I found was exactly the same, including the support brackets. Since in the U.S. oven elements are 220-240V rated, they will work in the La Germania (and Bertazonni) ranges. While I was at this used appliance store repair department I also looked for a replacement for the burned out lower oven element. Unfortunately I could not find an exact match for the lower oven heating element as I had for the convection element. However I did find a used domestic lower heating element that was approximately the same dimensions and wattage, and the end with the connectors very closely matched the original element, and so could be mounted and connected up exactly as the original element had been. I had to extend the two front support legs on it by about 1/2 inch, but that was easy to do with some scrap aluminum flat stock and a small bolt, a washer, a lock washer, and a nut to hold the extension in place.
I attached this extension to the bottom of the two V-shaped wire "feet" that were already welded to the front of the used element I had found. These two wire "feet" were welded at the top of the "V", so, being attached to the bottom of the "V" the extension wouldn't get the full heat from the element. This reduction in direct heat allowed me to use easier to cut and drill flat aluminum stock instead of using much harder to cut and drill flat stainless steel scrap stock. (I would not have trusted aluminum to withstand the heat of direct contact with the heating element.)
Because I was able to find workable domestic used parts, the total cost of repairing both elements was less than $20. It would have been far more costly just to have had factory replacement parts shipped from Italy.... I also was able to do the repair immediately instead of having to wait for the parts to arrive.
WARNING!!!! If using non-factory elements it is EXTREMELY important that you pay attention to closely matching the wattage of the existing elements. Putting in lower wattage elements will result in slower warm up times for the oven, and putting in higher wattage elements could be an EXTREMELY DANGEROUS FIRE HAZARD because the element would burn hotter than the stove was designed for and could potentially cause a fire due to this, OR it could cause a fire due to overloading and heating up or burning the supply wiring inside the stove because it wasn't rated to supply that high a wattage/current. WARNING!!!!
I realize that this kind of mix-and-match parts finding is not something that a person without some good DIY skills and experience would be able to do. However, competent professional repair people can and do use quality generic replacement parts all the time for out-of-warranty repairs -- they just make sure that the manufacturer is known for their quality and the wattage is an exact or very close match, and thus maintain the engineering and safety integrity of the stove.
3. Regarding getting factory replacement parts for these La Germania branded stoves:
While the parts can be ordered directly from Italy, I was quoted more than $100 just for shipping to get the parts I wanted shipped direct from Bertazzoni in Italy. Because La Germania and its parent company Bertazzoni produced very similar products, a great many of the parts were shared. Because of this, a Bertazzoni U.S. parts distributor like Reliable Parts will be able to supply many of the wearing parts (elements, burner caps, hinges, door seals, etc.) from their existing Bertazzoni stock. They would just need to contact their Bertazzoni representative and ask for the cross-matching part numbers between the two related companies when the part numbers differ. The U.S. parts distributors order a lot of parts at a time, possibly by the container load, which drastically reduces the cost of shipping for each individual part. So, if you aren't the experienced DIY type person that can work with matching and using domestic replacement parts, or just want to stay with the original factory parts -- attempting to get replacement parts through a U.S. Bertazzoni parts distributor could save you a lot of money (and time). I know this to be true because I researched getting the parts through Reliable Parts prior to discovering I could find and use domestic replacements.
4. The oven light bulbs for these stoves are hard to find, and expensive in the U.S. because of their shape and voltage. I was quoted between 8 to 10 dollars per bulb (not including shipping). However, if you do a search on a site like Ebay, you can find these bulbs for a lot less, even when considering the shipping cost. If you can wait for 2-3 weeks you can get a pair of these bulbs for about $2.50 from China or Hong Kong, including shipping. If you want to order from the UK to get quicker shipping, you can find them for about $8 for 2 including shipping. Just do a search for "25W 220V oven E14" or "25W 220V 300C E14" and you'll find them. Make sure they are high temperature rated (300 degrees Centigrade.) You can find them on Amazon as well, but I only saw Chinese suppliers listed (a 3-4 week shipping time usually indicates a Chinese seller).
Posted on Nov 09, 2009
taran_2005
taran_2005
  • 10515 Answers
SOURCE: Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 20, 2009
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
Takes an extremely long time to cook in oven, but elements seem to be working
If your oven has a digital timer then it is capable of being calibrated. Usually the oven is pretty close to accurate but can vary sometimes. In your user guide it may explain how to adjust the setting. You need to purchase a thermometer that you can put in your stove. Set it to 300 degrees and time how long it takes to stabilize. It is possible your stove will not get to 300 but to 270 or 280. If this is the case then the thermostat needs calibration. You can find out how to do this out of your guide or in the tech sheet that you should be able to find on line.
Jan 13, 2012 | Frigidaire 30 in. Electric Gallery Series...
Have shifted house, my Simpson Apollo ceramic oven won't work. The elements are fine. The timer and auto lights are flashing. I can't seem to make it stop. I have no user guide to help fix this error,...
The timer needs to be set to manual mode for the oven to work. Turn the oven control on. Play with the buttons on the timer. Try all combinations. It may take 5 or more minutes. When the oven indicator light comes on you will know it is on manual and the oven is working.
Feb 26, 2011 | Ovens
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
AEG Oven
You might get user instructions if you go to the folowing.
www.serviceforce.co.uk
Follow the instructions.
Plz leave feed back for this solution.
Thanks.. Make sure timer is set to manual and not auto.
Dec 09, 2007 | AEG B1180-4 Electric Single Oven
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
95 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
