SOURCE: microwave
F3 occurs if the controller detects a key shorted for more than 60 seconds. Luckily, on this model, the "keypanel" as it's called is available as a separate part. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering the model number here: http://tinyurl.com/gv383 The "keypanel" is shown as reference number 44 on that exploded view.
SOURCE: Kenmore Microhood 401.80089 - L SE L error
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: What does -F6- code stand for?
F6 means a problem in the control circuit board.
Try unplugging the microwave with the door open, then plug it back.
Try the solution that you find here, if it does not work the panel must be replaced.
SOURCE: sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
SOURCE: my microwave keeps beeping several times and i put
it junk replace it befor it burns u house down
