You have a pretty heavy drain on your battery. Find the fuse box. Remove all the fuses. With volt/ohm meter, read each fuse socket to find which one is drawing the power - when you find it ... investigate the circuit to find the short.
It may be that you are not making power ... your rectifier may be shorted which not only prohibits charging ... in some circumstances, it will actually cause a short to ground.
Maybe .... depends on your level of cleverness ...
Let me tell you about rectifiers ... then I will pass the ball to you .. you can run with it or you can drop it.
Alternators are NOT self exciting (you must put power in to get power out). Alternators make AC. Generators ARE self exciting, they make their own power to make power. They make DC. DC can go right into the battery ... if AC shows up at a battery ... it is of no value and may be of some danger. Your motorcycle has a alternator.
A rectifier accepts the output of a alternator and 'converts' it to rectified AC (it now looks like DC on a scope). The rectifier does this by clipping one-half of every AC cycle and sends it to ground allowing the other one-half to pass through to the battery.
If you had a flash light battery, a flash light lamp, two paper clips and your rectifier, you can test it as follows. First, make sure the light will light with the battery. (use the paper clips to make the connection). Next, with the rectifier unplugged from the circuit see if you can get the light to light through the leads on the rectifier ... if it lights ... great ... now, reverse the leads ... if the light still lights ... BAD, if it stays off ... GOOD. Power should pass in only one direction. You are 'creating' somethng that looks like "AC" to the rectifier by reversing the polarity (when you reverse the leads).
If your test results are not conclusive, you can have your rectifier tested at your motorcycle shop to be sure.
I hope this helps you resolve your problem.... ride safe.
Thanks for your interest in FixYa.com - thanks for the 4 thumbs up ... I need all of those I can get to get my average up.
My friend, I would like to contact you and ride with you ... Terms of use for this site preclude our contact outside this format, so I must say thank you for this vote of confidence, but I must respectifully decline your offer. Perhaps our paths will cross in a different venue.
I hope I have helped you with your motorcycle and I hope you will help others when your time comes.
Thank you
... so how are you doing with your situation?
thanks for your response. This of course brings up more questions.
Is there an easy way to test to find out if the rectifier.....(I think this is in the alternator)....is the problem....
Hi Milleraba, you've been super helpful, but I was wondering if you'd be willing to contact me directly if I gave you my email address?
