Question about HP LaserJet 3055 All-In-One Printer
Document loaded showing 3055
Hello all
i have a laser jet 3055 and it is showing the on lcd that document loaded error but printer is working fine only one problem that when i press copy and it start copy but it pick the paper from fax tray not from the scanner. how can i solved it plz tell me as soon as possible.
shanu
bye
Posted by loveshan on
PrinterTech
    Habit-Forming:
    New Friend:
  • 18 Answers
Sensor flag would have got stuck, check adf paper presence sensor
Posted on Oct 10, 2017
5 Related Answers
Anonymous
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
DrWho_64
Mark Cannistraci
  • 35 Answers
SOURCE: I can not get my HP laser jet 3055 to scan
More than likely, it's telling you it can't find the imaging device. Meaning it doesn't have one at all or it could be the drivers aren't installed for the scanner and can't be accessed. Try installing all the software that came with it. I'll bet you're just missing a driver. Installing the complete software package should install the driver for you.
Have you used the COPY function on this unit before? If you have then it's just a driver issue. You can download the drivers from HPs website. Just go to the customer service>tech support>downloads area and just locate your model number and serial number and that should be that.
Once you've downloaded it to your desktop, doubleclick the icon and follow the onscreen directions, You might want make sure the scanner is plugged in to the body of the printer. It won't work without it being connected.
Hope that helps, let me know if you're still having issues or if this was good advice for you.
GL!
Posted on Jan 15, 2010
Anonymous
SOURCE: memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
Posted on Feb 10, 2010
Anonymous
  • 54 Answers
SOURCE: how can I clear my fax memory hp laser jet 3055
go to advanced fax setup >>click on clear fax log..it will work
Posted on Mar 24, 2010
Anonymous
  • 160 Answers
SOURCE: laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Posted on Apr 20, 2010
I do not seem to know how to attach the scan of a document to an email with my HP Laser Jet 3055 All-in-One . Please tell me how.
Well once you scan the document, you save the document to any particular location (for example, your my documents folder). Then when you compose your email,click on the button to attach a file and browse to the location where you saved the document. Click on that document to attach it. Hope that helps.
Mar 14, 2011 | HP LaserJet 3055 All-In-One Printer
Where can i repair my hp laser jet 3055 in faridabad
hello,please kindly visit the site below to get assistance on where to repair your hp laser jet in faridabad,
http://dir.indiamart.com/impcat/color-printers.html
please kindly rate the solution if it's helpful,
take care.
Jun 11, 2010 | HP LaserJet 3055 All-In-One Printer
How can I clear my fax memory hp laser jet 3055
Hello !
You can clear the memory by doing an NvRam or hard reset
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
May 14, 2010 | Canon L120 Fax Laser Printer
Laser jet 3055 scanner error 6
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
I am having prob with ma HP laser Jet 3055
firstly restart the printer and put the blue wire into the red pocket vice versa it should work
Aug 13, 2009 | HP Office Equipment & Supplies
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
Printer not working
Contact HP tech support for a replacement bulb (or a quote on one).
Jul 04, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
542 people viewed this question
Ekse
efs_perpends
efs_perpends
