Question about Sony Handycam DCR-PC110 Mini DV Digital Camcorder
I have a handycam DCR-HC18e. The nightshot plus slider is set at off, but is still on as shown on the screen when I switch it on, and from the overexposed look of the recording....any suggestions?
    Sergeant:
  • 338 Answers
This has jammed, remove recording tape and perform reset.
Posted on Jul 03, 2010
6ya staff
SOURCE:
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Sep 06, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Aug 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DCR-HC51
This is the solution, I would only add that it's on the top of the camera itself. Not in the digital menu or backlight button. On my older version, it's between the cassette and lens sections of the camera.
Never having used the nightshot before, my sister left me with the same quandary...
Jun 29, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
How do you turn "Nighshot Plus" off
it should be right on the top of the camera. the big switch. its not in any of the touch screen menus
Feb 25, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Turning off nightshot
Maybe your blacklight is on. Hope that helps.
Mar 15, 2007 | Sony Handycam DCR-DVD505E DVD Camcorder
Nightshot Plus
If you really feel up to it the thing has screws, start opening them and take of the plastic cover. But think 4 times before messing with a 400 $ camera, maybe you'd rather take it to a lab, shouldn't be too expensive. There's many things that can go wrong if you do it yourself Good luck
May 14, 2006 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-PC110 Mini DV Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
