My Hp LaserJet m1522nf isn't receiving fax and its getting a comm. error, but i could send out fax. It could still scan and print.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
[email protected]
