Hi
Thanks for using FixYa. Before performing any repairs I’ll suggest you to reset
the TV by unplugging it for 8-10 hours. The blinking light means that the
protection circuit has been activated on the TV. This happens when there is
high voltage so the light starts to blink and the TV goes into protection mode.
Please check the high voltage section and main power supply for any
blown/swollen capacitors. All this is recommended if you have electrical
expertise and know how to solder/re-solder electronic components. Please make
sure to turn off and unplug the TV for at least 1 hour (this will drain off
current from all components especially capacitors) before you perform any
repairs. Also note that the TV consists of very high voltages even when it is
in off condition. Please do accept the solution if the issue is resolved or
post a comment for further assistance.
Thanks
Rylee
none of the lights are blinking
red LED comes on and off by pushing MAIN POWER SWITCH (push on/push off)
( I think) STANDBY POWER SWITCH will bring on green LED and TV, it's also a push on/push off
ROOT PROBLEM.. can't get TV to turn on ( have tried with cable remote, TV remote and front panel controls....TV was turned off using cable box remote
You’ll
need to open the back of the TV and check for any blown/swollen capacitors on
the main power supply board. Please do accept the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
