Question about RCA 36V430T 36" TV
Is it digital ready for over the air transmissions or will it need a digital cable box?
Posted by canddkeith on
Chi Chu
  • RCA Master
  • 8,457 Answers
This tv a analog tv,CRT tube tv don't have a digital tuner in side a analog CRT tv.Yes,buy the digital converter box to converter to recieve over the free digital air broscaast.
Posted on Jul 02, 2010
Analog to digital
If this is an older standard tv it is analog only it's not capable of processing digital tv transmissions in any way by itself you will need a digital tv converter box. thats true for antenna reception or cable systems that supply a digital signal,with digital cable systems you will probably need their digital converter box over the air & digital cable converters are not compatable with each other.
Apr 11, 2014 | Televison & Video
Is the AKAI LCT2785TA hdtv ready or does it need a hdtv kit/tuner?
According to the specs listed for this tv on Amazon.com this is a HDTV ready set. It should receive over the air HDTV transmissions without the need for any turner. If you are going to use over the air transmissions I would still have to recommend getting an HDTV antenna. If you are using a set top box from a digital provider, IE cable, FiOS, U verse, the set top box does the tuning anyhow.
Jun 17, 2011 | Televison & Video
Is emerson ewl20s5 tv digital or do I need a converter box?
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
I purchased in 2000 a Sharp 13" tv model 13N-M150. I used it with rabbit ears. Is this tv cable ready? If not, do I need a converter box? Thank you.
Yes,u need a converter box to get DTV free over the air signal.The converter box is not a cable tv box,it a free DTV free over air signal box,to help the old technolgy CRT tv tube anolg tv to get Digital tv signal.All CRT(Tube Tvs) must have a converter box to get free air Digital tv.Must have pay cable tv to get a signal,if don't have coverter box.If u have a crt tube tv or u get nothing,but statics.
Apr 27, 2010 | Sharp 13N-M150 13" TV
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
May 12, 2009 | Orion STV2763 27" TV
My ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Dec 20, 2008 | GE 25GT240 25" TV
Digital Cable Ready Question
Hey barfinkl1,
"Digital cable ready" TV's have a built-in feature that allows them to receive both standard and high definition signals, typically through the use of CableCARD technology instead of a set-top box.
While this specific Samsung model (HL61A750) is not digital cable ready, it does feature both an ATSC and Clear QAM tuner. This means that it should still be able to receive locally broadcast and unscrambled over-the-air digital signals, but will require a set-top cable box to receive any kind of scrambled digital signal.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 17, 2008 | Televison & Video
RCA 36V430T 36" TV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
