Question about Danby Silhouette DWC512BL Wine Cooler
Our wine cooler is making a loud noise. We
Our wine cooler is making a loud steady noise. It is about 2 yrs old. We haven't left it plugged in long enough to determin whether it is still cooling.
Posted by pvreith on
RJ motortech auto repair
    Habit-Forming:
    New Friend:
  • 75 Answers
I got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Posted on Jul 08, 2010
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Fridge makes a fairly loud popping noise at intermittent intervals...otherwise works fine and maintains wine temp as set....makes this noise approx 10-15 times a day....unable to determine any set pattern...
What you are hearing is the new refrigerant going through the system. The old Freon 12 did not make that noise but the new stuff does. Nothing to worry about, it is normal. Thank you for using Fix ya and I hope you found this info helpful.
Jun 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
My magic chef wine fridge keeps making a loud popping noise every 15-20 minutes. It s model # WCMC458?
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
Aug 15, 2010 | Magic Chef MCWC45A Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
Danby Silhouette DWC512BL Wine Cooler Logo
1,981 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Danby Furniture Expert? Answer questions, earn points and help others
