The loud pop that resonates through the speakers when the tuner turns on could be caused by a number of factors, including a problem with the tuner itself or an issue with the amplifier or speakers that are connected to the crate flexwave 120. Some potential solutions for this problem include:
Checking the connections between the tuner, amplifier, and speakers to make sure they are secure and properly connected.
Making sure that the tuner is properly grounded and that there is no interference from other electronic devices in the area.
Checking the volume level on the amplifier and speakers to make sure they are not set too high, which can cause distortion and popping sounds.
Checking the settings on the tuner to ensure that it is properly configured and that the correct input is selected.
Replacing the tuning capacitors in the tuner.
If all the above steps are not helpful, the problem might be a hardware failure, you may need to get it inspected by a professional technician.
It's also possible that the problem may be caused by a malfunction in the tuner, in which case it may need to be repaired or replaced.
World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
32 inch LCD TV with 3 HDMI inputs and PC input
USB input for direct media playback
45,000:1 Dynamic Contrast: While viewing either very
bright or very dark scenes, it can be difficult to distinguish main
images which blend into the background.
Dynamic Contrast dramatically mitigates this problem by
adjusting the backlight intensity, providing up to a 4X improvement in
contrast.
6.5ms Response Time
Widescreen 16 X 9 Format
World-wide Dual Voltage 110-240 volts 50-60 hertz
HDTV monitor (HDTV tuner required for HD reception)
This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
To watch digital channels (ATSC Broadcasting in US and DVBT
broadcasting overseas) you need a digital source/tuner like a cable box,
digital tuner, satellite service, etc.
To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
Component Video Input offers the best video quality for
DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p
and 480i) connections.
PC Input allows you to connect your PC and display the PC screen on your TV.
Specifications
Display
Image Aspect Ratio:
16:9
Widescreen Modes:
Conventional 4:3
Comb Filter:
3D digital
Additional Features:
V-Chip, parental control
Diagonal Size:
42" - widescreen
Display Format:
1080p (FullHD)
Resolution:
1920 x 1080
V-Chip Control:
Yes
Image Contrast Ratio:
2500:1
Brightness:
500 cd/m2
TV Tuner
Stereo Reception System:
MTS
Secondary Audio Program (SAP):
Yes
Analog TV Tuner:
NTSC
Video Features
HDTV Ready:
Yes
Analog Video Input Signals:
NTSC
Input Video Formats:
1080p
Remote Control
Type:
Remote control
Audio System
Sound Output Mode:
Stereo
Sound Effects:
Virtual Dolby Digital
Speakers Included:
2 speakers
Mute button
Speaker(s):
2 x right/left channel speaker - built-in
Connections
Connector Type:
1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 )
Power
Power Device:
Power supply - internal
Power Consumption Operational:
240 Watt
General
Product Type:
42" LCD TV
TV Tuner:
1x analog, 1x digital
Width:
41.3 in
Depth:
10.2 in
Height:
29.7 in
Weight:
55.1 lbs
HDCP Compatible:
Yes
Digital Television Certification:
HDTV
Digital TV Tuner
Digital TV Tuner:
ATSC, QAM
Additional Specifications
HDMI:
Y
More Information
Model No.:
DP42848
Shipping Weight (in pounds):
67.0
Product in Inches (L x W x H):
41.3 x 10.2 x 29.7
Assembled in Country of Origin:
USA and/or Imported
Origin of Components:
USA and/or Imported
Walmart No.:
000503420
press setup/configuration on your remote you'll get configuration menu, then goto 'speaker configuration' check if the subwoofer is on, check that front speakers and others are set as small. There also could be subwoofer mode settings, remember current setting and try to change it.
Troubleshooting Kinect audio problems
Page ContentBelow is a list of common Kinect audio problems along with suggested solutions. If you are experiencing... Try this...
An echo
Turn off digital
effects on your audio receiver. Digital effects include things such as
reverb, compression, and synthesized surround sound modes.
If you are using a TV and an audio receiver at the same, turn off the volume on the TV.
Use the Kinect Audio Tuner.
If you are hearing an echo during Xbox LIVE gameplay but not while
you are playing offline, the problem might be with another player's
Kinect sensor. Ask the other player to run the Kinect Audio Tuner.
No sound from one or more speakers
Make sure that the Xbox 360 A/V cable is properly connected to your audio system.
Make sure that all speakers are connected to your audio system.
If your audio system has speaker switches, make sure that the switches are on.
If your audio system has a receiver mode, make sure that the setting matches the number of speakers connected. For example,
If you haveUse this mode
Two speakers
Stereo
Five speakers and a subwoofer
5:1
Seven speakers and a subwoofer
7:1
Kinect voice commands are not working
Run the Kinect Audio Tuner
Your friends cannot hear you during chat
Make sure that the chat microphone on the Kinect sensor is on. Here's how:
On your console, go to My Xbox, and then select System Settings.
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls. http://support.radioshack.com/support_audio/doc61/61792.pdf
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
