Question about Samsung ML-1640 Monochrome Laser Printer
Samsung ml1640 laser red light blinking
Samsung ml1640 laser red and green light blinking continuously and printing not happening
Posted by anujarao72 on
Anonymous
    New Friend:
Posted on Oct 01, 2010
delpasillo
    New Friend:
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Posted on Oct 24, 2012
MR KHAN
    New Friend:
Delpasillo Thank you so much. I follow your instruction & my problem has been solved. Cause printer cancel button are jam. ??? ????? ???????? ??????? ????? ??? ?????? ??????? ??????????? Cancel ?????? ???? ?????
Posted on Jan 12, 2015
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
Samsung CLP-315 This unit has seen very little use. Perhaps 100 pages. It sat idle for 9 mos. while we were in FL. When I returned home I turned it back on and printed 1 page with it. I thought all was...
It is possible that it reciecved a small power surge while you were gone on your trip, and you need to leave it unpluged from the wall for 40 Min, to clear and reset the operating processor.. It should go back to normal after leaving unpluged, but you might have to run set up program agian too.
Jul 28, 2011 | Samsung CLP 315 Laser Printer
I HAVE SAMSUNG ML1640 - RED LIGHT IS BLINKING AND PRINTER IS NOT RESPONDING
Have you put paper in the tray,
do it and reboot you printer
and if you have played with firmware, that has made changes to firmware you need to restore your previos setting of firmware.
Mar 04, 2011 | Samsung ML-1640 Monochrome Laser Printer
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
Feb 03, 2011 | Samsung ML-1640 Monochrome Laser Printer
I purchased sumsung ml1640 printer catraige newly fill up after printing not came became a error came toner exhausted. please solution me.
it is very simple but need some electronic soldering knowledge. simply solder a piece of wire as in this picture. your printer never say "toner exhausted"
Sep 01, 2010 | Samsung SCX-4300 Monochrome Laser...
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
I have a ML-2510, I turned it on and both the red light and green light flash constantly. Will not feed or print.
The green light blinking means that it is accepting or printing data.
But, the red light is for the error messages. This blinking means there is a toner problem. 1. remove toner cartridge from printer and gently shake to redistribute any that is left, or
2. You simply have to replace the toner cartridge with a new one - this one has been exhausted.
Jul 09, 2009 | Samsung ML-2510 Laser Printer
Blinking Lights
Do you have a paper jam? If nothing is wrong it may be internal hardware error. Call Samsung for help.
Apr 04, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-1640 Monochrome Laser Printer Logo
4,516 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
