hello sir .. does your batteries are charged already?? if your batteries are fully charged and your camera didn`t turn on, there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Have your camera battery been charged fully?
It seems problem about battery or the lens
If your battery are AA batteries please note the battery type of the battery if your camera support
else
If the battery is OK, there maybe something wrong with the lens
Is you battery have charged? You need to check your Kodak camera battery is well at first.
You can change another battery and to see if the before on is ok.(or is there is a good connection between your battery and battery box).
If you battery is OK, there maybe some other problem with the camera, maybe you will get a message before if turn off.
You can check your battery with multi meter is that ok or not.Other way check with any friend camera
You confirm battery is ok.As you says battery fully charged then must be problem with Main board.
After confirm Battery ok you need to replaced Main board.Main board can be repair but need so Tool which is only have in service centre so go to your near service centre to fix it.
I have the same problem. battery ok. memorycardvieuwoke, but when turn it on to camera , it is "dead"
please if someone have a solution for this;
Email' [email protected]. Thanxx. ranjan
clean the contacts of the battery/battery comparment,if you get it camera ON its OK if u failed camera power section faluire/take it to the kodak service
Did you reolaced battery that evening, if you did then try holding the battery door tight and the turn it on. If this will solve it it means that there is a play in battery door that happens very often if someone is not careful enough while replacing battery or merory card.
