Question about LG GT505 Cell Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
Posted by vijayarajan2 on
Anonymous
  • 677 Answers
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Posted on Jul 02, 2010
I am unable to pair my H720 Bluetooth headset to my LG d500cell phone
Hi Beatrice,
You can check this link H720 Bond Pair for more information about how to pair your Bluetooth device.
Regards,
Maya
Motorola Support
Feb 01, 2016 | Motorola Mobility H720 89382N Bluetooth...
What is the bluetooth passkey code for lg vn251
As far as I know the default passkey for the Pioneer AVIC devices is 1111 (four ones). By the way, it seems that there two ways to pair this device. If, after display the settings menu and selecting 'Bluetooth settings', you choose 'Register from mobile phone', after you phone is paired, all subsequent connection requests will be started from your phone. Otherwise, if you choose 'Select specific devices' instead, all connections will be started from the navigation system.
Hope you are able to get your navigation system fully functioning soon.
Anyway, please, let me know if you need further informations.
Best regards,
Carlos
Oct 24, 2012 | LG GT505 Cell Phone
How i connect my lg gd510 with the laptop using bluetooth.sir i download lg pc suit but when try to connect then it ask password for mobile and and i donot know what is it? help me
When you are pairing any two 'smart' bluetooth enabled devices, like phones and computers, i.e. devices which act as bluetooth hosts, in the device where you are starting the pairing procedure, you can specify any digit sequence you can think of, provided that in the the other device, the one which will receive the pairing request, you specify that same passkey, because you will notice a request for that on the screen. Of course you can specify the passkey which is widely hardcoded in 'dumb' devices, like headsets, i.e. '0000' (four zeros, without the quotes). You don't need to worry whether the passkey looks too simple or not, because the devices will be paired to each other just once, under a process which is strictly controlled by you, and all subsequent connections between those devices will be encrypted.
Hope it works for you. Anyway, since english is not my natural language, please, let me know if I have misunterstood you. I'll do my best to try to help you out.
Regards, Carlos
Jul 24, 2011 | LG GD510 Cell Phone
LG Cookie bluetooth problem
There is a difference between "pairing" and sending files. You normally have to negotiate a security protocol to send files where you enter a passkey on one device and then do the same on the other
Jan 30, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to get a bluetooth passkey
hi there,
if you are pairing the bluetooth headset device with your cell than the default passkey is 0000 (you can also check the user guide for bluetooth headset). and that will work with your phone.
if your pairing the phone with other phone then you need to create your own passkey to pair it with other device (try 1234) and the same key you have to write on other phone once you will do that your phone will be paired and you are able to use it.
i hope it will help you.
best of luck
Mar 23, 2009 | LG RUMOR Cellular Phone
Lg prada ke850
As long as you enter the same code on both devices it pairs fine. I use 0000 on my mobile and the same on my laptop. There is no specific code.
Now, can you tell me where to get software for mine, please?
Jun 21, 2008 | LG Prada KE850 Cellular Phone
Don't have bluetooth passkey
When you pair with someone you need a key(bluetooth passkey) for your mobile..for eg.
if A wants to pair with B.what he do is ,he go to the bluetooth menu .switch 'ON' to the bluetooth device and also selects 'shown to all' option so that other device can find that mobile .Now B also has to do same thing i.e switch 'ON' the mobile and 'Show to all'..Now Device A will search for other devices ,and when the search is complete you see the name of that mobile .now you click on that mobile and select to enter pass key..for eg 123 ..Now other mobile will get the message that Device A wants to connect to you i.e Device B.So same passkey 123 is to be typed in order to make pair............
Jun 01, 2008 | Cell Phones
LG GT505 Cell Phone Logo
780 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
