Question about SanDisk Sansa e250 MP3 Player
Right in the middle of a book I was listening to I get the message "synchronize to continue your music subscription" I am not listening to music I am using my mp3 player for audio books. What have I done wrong???
Joe Negus
    President:
  • SanDisk Expert
  • 652 Answers
Format and sync reload your books
Posted on Jul 04, 2010
I have a message on my sansa clip that I want to get rid of so that I can continue to listen to my book. I can't listen till this is straightened out. It says synchronize to continue your music...
Audible books are protected, you can copy them into device, but you can't play them (...subscription...appearing ). You must use audible manager to sync audible books.
You should delete audible books that make pop up a message " synchronize to....", otherwise, your device always pops up the message when it meet the audible books.
Message" synchronize to continue your music subscription"
Hello
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Synchronize to continue your music subscription
You will need to sync the deivce to Rhapsody or whatever msuic svc you have been using. If the subscription has lapsed, you will not be able to use the songs anymore.
1helpful
2answers
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
4helpful
Synchronize To Continue Music Subscription
1. go to the settings menu on your player
2. go to USB and change it to MTP
3. Plug it into your PC
4. Open My Computer and right click on your player
5. Click on format
6. open windows media player
7. click on library and start adding songs to your player
8. click on "sync" at the bottom of the playlist on the right
9. that should do it!
Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
2answers
"Synchronize to continue your subscription"
To get rid of that message, you need to connect your Sansa to your computer and open the Rhapsody software to "deauthorize" your Sansa (assuming that you're not going to be using the Rhapsody service). The following URL gives you two options on how to deauthorize your device (look at the bottom section of the page): http://home.real.com/product/help/chandler/en/instruction/auth_deauth_pd-textonly.htm
Synchronizing?
You have to be playing the book in Windows Media as you sync. It works then. My problem is that is loads the entire book as 'one' so you can pick up in the middle.
3answers
Synchronize to continue your music subscription message
I received the same error message. When you download a file from a subscription service, such as an audio book from a public library, you usually have to open the file on your computer first, which I believe, "activates the subscription" with the appropriate license. Some of the services pop up a screen telling you that your license is activated, but others, such as Overdrive, seem to do this automatically. When I downloaded a book and transfered it to a Sansa c240 mp3 player, I received the "synchronize" error message, but when I went through the above procedure and transferred to the mp3 player, no problems, and no error messages. [email protected]
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
