Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
Empty boiler how do I empty a 350L rhem boiler? I I need to move the boiler in an other room and full is way to heavy.
Posted by massimgo on
Randy Marshall
  • 349 Answers
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Posted on Jul 03, 2010
Worcester 28i junior , won't come on, I have no heating but have hot water
First check, in there a room thermostat fitted. If not look at the boiler timer if a circular clock type move the side slider to gentral position and set the timed pins do that when the clock face rotates the pins operate the boiler heating on switch OR if a digital type press the button marked mode to so that on the display there indicator bar moves to the on position.
Dec 11, 2017 | Water Water Heaters
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Greenstar 24i junior
Replace the thermosts,signal not getting thro to boiler.
Jul 15, 2017 | Water Heaters
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
Boiler coming on,on its own
Sounds likely. But check the timer selector switching [on/off/24hrs] & if you have a room thermostat wired in
Jun 13, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Smell of oil throughout the house when the boiler is on
Other than the stench of fuel oil permeating every soft surface throughout the house, there are numerous health hazards associated with exposure to petrochemical vapors. Shut the unit off until you can get it repaired.
Mar 16, 2009 | ACCO Brands Water Heaters
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
130 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
